I should have known it was a Windows issue!!!!!
"Error opening sound device"
bigJohnny59
Re: "Error opening sound device"
Thank you so much for sharing this!!!!!!! I have a new TEAC turntable, and I couldn't record from either Audacity or Golden Records Converter. I tried everything I could think of and was about to throw the turntable out the window!!!!! Everything is working great now!!!!!!
This is replay for many people here.
By receiving this message 'Error opening recording device. Error code: ´9999 Unanticipated host error'
do the follow: Enter Configuration and in Privacy , select microphone . Check if it is grayed or not.
Please Help?
I have this same "error opening sound device" error.
I see you all have the solution!
Why can't I see it?
I am running windows 7
Where is this "Settings" you all refer to?
Where then is this "Privacy" tab?
Are we in Microsoft Windows or Audacity?
(I can't find these tabs in either)
I have scoured google & youtube for a solution but they are rare & indecipherable to a non-techie like me......highspeed videos of unreadable actions on a PC. I have updated Audacity as well 2.1.0
Why can't I see it?
