waxcylinder wrote:what we have to remember is that this is not a beginner's tool (or even a tool for the low-skilled to average-skilled user).
I am not sure I agree. The major gap we have is there is nothing between the non-GUI fades and Envelope Tool. I am comfortable with making this low to average skilled, but let's remember that most users are not mathematicians.
steve wrote:
The big problem with dB values on sliders is that the sliders in Nyquist plug-ins are linear scale.
(you usually end up using text input instead of the sliders)
Can this be mitigated to some extent by skewing the scale so it contains the entire useful range (goes above 0)?
And you can still drag the sliders, or click to get near, then drag?
waxcylinder wrote:And I think I'm with Steve in not wanting per-cent.
But you've already said you are not a user of this effect. I'm trying to help people who want to use it but who will struggle with linear gain and confuse it with the linear vertical scale and therefore see it as a target.
steve wrote:
Code: Select all
;control a "Start and End points as" choice "Gain,dB gain,% of original" 0
If we want a linear gain in the choices then I think it should be called that, probably "Gain (Linear)".
Also I am not sure in the 26, 26a, 26b versions that it is clear enough that you can enter positive dB gains (hence my idea of adding "+ or -" in the choice text).
