Isochronic Modulator Plug-in
Archive of Nyquist Plug-ins.
Many of the plug-ins here will be available on the Audacity Wiki.
This Forum is an archive of old topics concerning Nyquist plug-ins.
Feedback and questions relating to topics may be posted, but please
DO NOT POST NEW TOPICS HERE.
New plug-ins may be posted on the New Plug-Ins board.
Other posts relating to Nyquist should be posted to the main Nyquist board.
The main repository for Audacity/Nyquist Plug-ins is on the Audacity Wiki.
Evollution
Re: Isochronic Modulator Plug-in
Post by Evollution » Wed Jul 06, 2011 7:50 pm
1.I need a little help
How to make Alpha - Beta - Theta - Delta Tones ?
and 2
How To Create Isochronic Tones Ramp ?
What variables should i change ?
stpweb
Post by stpweb » Sat Nov 12, 2011 3:29 am
'Pulse Width' must be set to 50 to achieve an isochronic tone.
'Initial Modulation Frequency' and 'Final Modulation Frequency' is the isochronic beat you want to
target. They must be the same unless you are creating a ramp.
"Initial Modulation Depth' and 'Final Modulation Depth' must be set to 100 to get a pure isochronic
beat.
You can play around with 'Fade Time'. The lower the value the truer its isochronic waveform is. As
the value gets higher, the silence portion gets smaller. I find the value of 15 to be acceptable.
That's it, you now have an alpha isochronic beat.
Ramping the Isochronic Beat
IsoMod supports ramping but you can only create it one time either going from a high frequency to a lower frequency or from a lower
brainwave frequency to a higher brainwave frequency. If you're designing an
isochronic tone which ramp more than one time, you need to create several tones then just 'stitch' them together.
As an example if we want to start with 10hz alpha brainwave then ramp to 4hz thetabrainwave then back again to alpha brainwave,
you need create at least 4
isochronic tones. Details may be as follows:
1. 10hz = 6min
. 10hz to 4z ramp = 2min
. 4hz = 6min.
4hz to 10hz ramp= 2min
2. Create a 10hz tone
Open another instance of audacity and
create 10hz tone for 2min. Ramp it down with IsoMod to 4hz
create a 6min 4hz tone
create a 4hz tone for 2min Ramp it up with IsoMod to 10hz
3. All you have to do now is copy and paste to
create a single file. You may however need to edit the waveform in the
'stitched' portion.
That's it! Have fun and may you reap the benefits that
isochronic tones can give you.
Seanwill88
Post by Seanwill88 » Mon Jun 27, 2016 12:10 am
Hello
I am having trouble installing the Isochronic Modulator plug in. I have the current operating system for Mac El Capitan 10.11.5, I downloaded the current version of audacity and tried to install the plug in like is says here and it never showed up. So I downloaded an older version of audacity and tried again and still didn't work.
Does this plug in still work and does it work with the latest version of audacity?
What am I doing wrong here?
Thanks so much
Post by Gale Andrews » Mon Jun 27, 2016 1:29 pm
We want you to download Audacity from us at http://audacityteam.org/download/mac and tell us that you have Audacity 2.1.2 or 2.1.1 (see Audacity > About Audacity... to check your version number). If you download elsewhere, things may not work and you could even harm your computer with a virus.
When you have 2.1.1 or 2.1.2 from us, add isomod.ny to the Plug-ins folder where you installed Audacity. Open Effect > Manage... (in 2.1.1) or Effect > Add / Remove Plug-ins (in 2.1.2), press the "New" radio button, click to select IsoMod, click "Enable" then OK.
This works in 2.1.1 or 2.1.2 on Mac, I have just tried it. Make sure at Audacity > Preferences..., Effects section, that the "Nyquist" checkbox has a tick (checkmark) in it.
Seanwill88 wrote:I am having trouble installing the Isochronic Modulator plug in. I have the current operating system for Mac El Capitan 10.11.5, I downloaded the current version of audacity and tried to install the plug in like is says here and it never showed up. So I downloaded an older version of audacity and tried again and still didn't work.
lonhowell25
Post by lonhowell25 » Thu Aug 04, 2016 6:56 pm
I cannot find a download for IsoMod that works. Is this plugin still available? Does anyone have a current link?
Thank you.
Post by Gale Andrews » Fri Aug 05, 2016 4:04 pm
lonhowell25 wrote:I cannot find a download for IsoMod that works. Is this plugin still available? Does anyone have a current link?
The file is here http://wiki.audacityteam.org/wiki/Nyqui ... _modulator.
Obtain the correct 2.1.1 or 2.1.2 version of Audacity from http://www.audacityteam.org/download/mac and follow the instructions in the previous post: http://forum.audacityteam.org/viewtopic ... 77#p307977.
lonhowell25
Post by lonhowell25 » Sat Aug 06, 2016 6:59 pm
For some reason that file downloads as a document that I cannot open. Can someone help? Am I doing something wrong?
lonhowell25
Post by lonhowell25 » Sat Aug 06, 2016 7:13 pm
Please disregard, I figured out what I was doing wrong. Thank you Gale!
zack348
Post by zack348 » Wed Feb 01, 2017 1:50 pm
Ionhowell, can you share your fix for getting the Isomod plugin working with the more recent versions of Audacity? I'm placing the file in the plug-ins folder but it is not showing up when I in to the menus to add the effect.
thx!
Post by Gale Andrews » Wed Feb 01, 2017 2:45 pm
zack348 wrote:Ionhowell, can you share your fix for getting the Isomod plugin working with the more recent versions of Audacity? I'm placing the file in the plug-ins folder but it is not showing up when I in to the menus to add the effect.
lonhowell25 is not Forum staff and is unlikely to be reading now.
What version of Audacity are you using? Please give us all three numbers from Audacity > About Audacity... . In Audacity 2.1.2 you have to use Effect > Add / Remove Plug-ins..., select the new plugin you want to add, click "Enable" then click OK. In 2.1.1, the menu item is called "Manage".
Make sure you are not running Audacity from the DMG. Make sure at Audacity > Preferences..., Effects section that the "Nyquist" box is ticked (checked).
Are you on macOS Sierra? If so you may have to follow the solutions at http://forum.audacityteam.org/viewtopic ... 41#p316041 to get plugins to appear in the menu.
