This plug-in was originally developed in response to a request for a way to "stretch" the pauses in a language tutorial recording so that the user has more time to repeat each phrase. The plug-in is not restricted to speech recordings - it may be used in any type of recording where there is a need to extend the silences within the recording.
The plug-in code has copious in-line comments that describe how the plug-in works.
To view the code, open the plug-in file ("ExtendSilence.ny") in a plain text editor (such as NotePad or the excellent NotePad++). For more information about Nyquist code, see: http://forum.audacityteam.org/viewtopic ... 39&t=77214
How it works:
The plug-in scans the selected track, looking for places where the audio level remains below a specified level (the "Threshold") for more than a specified period. These places are classified as "silences". The plug-in then extends each detected "silence" by inserting additional silence at the end of each detected silence.
The amount of silence inserted may be defined in three ways:
- As an absolute length (in seconds).
- As a proportion of the length of the detected silence.
- As a proportion of the length of the preceding sound.
For example, for a language tutorial CD, you may want to extend each "pause" by 50% of the length of the preceding phrase, plus 2 seconds. The resulting silence will then be:
{the length of the detected silence} + {50% of the length of the preceding phrase} + {2 seconds}
Controls:
- Threshold for silence (dB): [-100 to 0 dB. (default = -40 dB)]
The peak level needs to drop below this level to be counted as "silence". If there is background noise, the threshold will need to be raised to a higher (less negative) level. - Min detected silence (seconds): [0.1 to 10.1 seconds. (default = 1.0 seconds)]
If the audio remains below the Threshold level for at least this length of time, it will be classed as "silence". Set to a smaller number if you wish to extend short gaps, or to a larger number if you wish to extend only long silences.
Values greater than 10 seconds (up to 100 seconds) may be entered by typing into the text box. - Add silence duration (seconds) [0 to 10 seconds (default = 5.0 seconds)]
This extends each detected silence by the specified amount.
Values greater than 10 seconds (up to 100 seconds) may be entered by typing into the text box. - Add % of detected silence duration: [0 to 100 % (default = 0 %)]
This extends each detected silence by an amount equal to a specified percentage of the detected silence. For example, if the detected silence is 10 seconds duration and this control is set to 50%, then 5 seconds of silence will be added.
Values greater than 100 % (up to 1000 %) may be entered by typing into the text box. - Add % of previous sound duration: [0 to 100 % (default = 0 %)]
This extends each detected silence by an amount equal to a percentage of the duration of the preceding sound. For example, if there is a sound of 10 seconds duration before the detected silence, and this control is set to 50 %, then 5 seconds of silence will be added.
Note leading silence before the first sound will not be extended by this control because there is no preceding sound.
Feedback and comments from plug-in users are an essential part of developing useful plug-ins.
For feedback, comments or questions, please post a reply to this topic.
