As a result of a recent enquiry on the developers mailing list, I had a look through some of my old plug-ins.
There is an old plug-in by Edgar-rft which is on the wiki (documentation and a minor bug fix updated today) http://wiki.audacityteam.org/wiki/Nyquist_Analyze_Plug-ins#Peak_Finder_rft
and here is an old one that I wrote which I have just updated (bottom of page).
This plug-in can either:
- Locate the highest peak in the selection.
- Locate peaks that are over a given threshold level (dB)
(The “stf” suffix to the name is just to distinguish it from Edgar’s plug-in.)
Parameters:
- Time accuracy: [Choice: Normal,Best (slow). Default = Normal]
- The normal setting will create a region label around the detected peak. If only the highest peak is being detected, the region label will be 1/100th second long. If peaks above the threshold are being detected, the region labels will be 1/100th second longer than the peak.
- “Best (slow)” usually takes much longer to process (up to 10 times slower) but is accurate to within one sample period. If only the highest peak is being detected, a point label will be created close to the highest sample value. If peaks above the threshold are being detected, region labels will be created around each peak from immediately before the first sample to exceed the threshold value, ending immediately after the final sample of the peak that exceeds the threshold value.
- Peaks to find: [Choice: Max peak only (default), Peaks above threshold]
- When “Max peak only” is selected, if there is more than one peak at the maximum level, the first peak to reach the maximum level will be labeled.
- When “Peaks above threshold” is selected, all peaks that exceed the threshold level will be labelled.
- Note that peaks may be up or down. The plug-in does not differentiate between positive going peaks and negative going peaks."
- Threshold (dB): [-15 dB to 0 dB. Default = -3 dB] This control is ignored when labeling only the maximum peak.
- Maximum number of labels: [1 to 10000. Default 1000] Sets a limit to the maximum number of labels that may be created.
peakfinder-stf.ny (2.9 KB)
