Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
- Site Admin
Post
by steve » Sat Feb 03, 2018 12:44 pm
msputman wrote:Sorry very frustrated - I can't get the De-Esser to show up under plugins. I followed the links you posted above about how to install .ny plugins - when I navigated to Library/Application Support/audacity there was no Plug-Ins folder at all.
I wound up copy pasting the De-Ess and De-Click .ny files into that folder and then tried all the folders under library/audio/Plug-Ins as well - no luck.
Ultimately I got so desperate I created the Plug-Ins folder under library/application support/audacity with no luck.
Any advice from anyone? Would really appreciate it.
Which version of Audacity are you using? (look in "Audacity menu > About Audacity").
How did you install Audacity?
Look in the "Generate" menu - do you see a menu item called "Rhythm Track"? If so, does it work (see:
http://manual.audacityteam.org/man/rhythm_track.html)
msputman
Post
by msputman » Sat Feb 03, 2018 12:53 pm
Wow thanks for the quick reply.
I'm in audacity 2.2.1 and I just re-installed from the website. Rhythm track is available and opens into a large menu.
I installed by launching the standard dmg and did the click-drag into applications folder thing.
msputman
Post
by msputman » Sat Feb 03, 2018 12:58 pm
Sorry earlier post didn't go through. Thanks so much for the quick reply.
I'm using Audacity 2.2.1. Rhythm track is present and works.
I'm on a Mac and updated the OS to make sure that's not the issue.
- Site Admin
Post
by steve » Sat Feb 03, 2018 1:48 pm
msputman wrote:Sorry earlier post didn't go through
It did, but there is a "moderation queue" that delays posts appearing (so that the forum moderators have chance to weed out the copious spam that gets posted).
- Site Admin
Post
by steve » Sat Feb 03, 2018 1:53 pm
msputman wrote:when I navigated to Library/Application Support/audacity there was no Plug-Ins folder at all
You may have the wrong folder. I think there are two similarly named folders on Mac.
The one that you want is:
~/Library/Application Support/audacity/Plug-Ins
where "~/" means your home folder.
msputman
Post
by msputman » Sat Feb 03, 2018 2:22 pm
Fixed!!! Amazing. That was driving me nuts. Really appreciate the help.
bribri
Post
by bribri » Mon Feb 19, 2018 8:52 pm
kozikowski wrote:Once you place the file in the Plugins folder, close everything back out to the application. Don't try to launch it.
In Audacity, Effects > Add/Remove Plugins. You should be able to find it and activate it. I've been known to select them all and install everything.
From there, open your show and apply it.
Hi again, late reply as was busy with other commitments then simply forgot! Thanks for your help. Unfortunately I can't find it at all and I believe I am doing everything you said. As you can see from the attached image, the De-Esser.ny file is in the Plug-Ins folder within the audacity folder.
The only thing I can think of that may be of relevance is that I had to manually create the Plug-Ins folder and one wasn't in initially in the Audacity folder.
Again thank you for any assistance. it is much appreciated and apologies in advance if I have overlooked - or do overlook - something glaringly obvious.
bribri
Post
by bribri » Mon Feb 19, 2018 10:02 pm
Please disregard the post I just made - I have two admins on my Mac and think that was the problem. Spent all evening deleting one admin and have sort of solved the problem but will make a new post in the morning with the new problem that has since been created (I'll try to resolve it first myself!).
menmoirs
Post
by menmoirs » Wed May 09, 2018 6:56 pm
This is great, once I figure out how to get it installed I'll be a happy camper (assuming it works).
For now I'll keep turning down the treble in problem areas if I can't edit them out.
Thanks again.
planetlizz
- Operating System: macOS 10.11 El Capitan
Post
by planetlizz » Sun Aug 12, 2018 11:27 pm
So many hours wasted trying to get to the bottom of this
OSX 10.6.3
Audacity 2.2.2
HI IM LIZ AND IM A DECLICKER-AHOLIC. Finally going back to my Mac. Holy cow idk how Gates sells any of that junk.
So Downloaded Audacity (2.2.2) ... DL Lame ... BUT the dang DECLICKER plugin keeps downloading as a .php file whether left or right clicked (save as). ive got 5 declicker.php files in the plugin folder and ZERO .ny files
I also noticed that hardly any EFFECTS are available ... all common ones ... ive done the ENABLE/DISABLE/NEW under effects but like only 6 or 8 effects show as available ... none that i use. i did notice that all the Apple FX are available ... dont use them either.
H E L P por favor!!
