Updated De-Clicker and new De-esser for speech
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Re: Updated De-Clicker and new De-esser for speech
Post by Gale Andrews » Sat Apr 29, 2017 2:59 pm
steve wrote:
Gale Andrews wrote:I guess the issue is that Audacity does not check to see if the defaults actually changed and if so update the defaults.
It doesn't, and what's worse, it retains the default setting even if the plug-in is removed (either via the Plug-in manager, or physically removed).
A possible fix might be to unset the "initialized" token when a plug-in is removed, or 'missing'. This could allow the last used and custom presets to be retained in case the plug-in is added back later, but would force the defaults to be reinitialised. I've not yet worked out how to do that, but I'd say it's a 'bug'.
That seems like it could be a good solution. Given we store settings, it would seem unwise to default-discard them if the plugin is removed.
Plug-in Manager has no way to actually remove plugins, only to disable them, retaining their entry in pluginregistry.cfg. Possibly a "Remove" button could be considered with a Yes/No dialogue and a checkbox "Also delete plugin settings".
1000Words
Post by 1000Words » Sat Dec 09, 2017 5:51 am
Hi All, Not sure if Paul L or MichloIW are still around, but I'm new to Audacity & in need of the De-Esser plugin. I downloaded the two links at the end of Paul L's post but when I try and open them I get this popup. When I go to "choose application" Audacity isn't even a choice. I have the same issue following the DeClicker plugin as well. Any advice? I am on a MacBook Pro with MacOS Sierra 10.12.6
Screen Shot 2017-12-08 at 10.50.13 PM.png (69.13 KiB) Viewed 1613 times
Reason: Put image inline to preserve board layout
Post by steve » Sat Dec 09, 2017 1:42 pm
Plug-ins that are named with ".ny" as the file extension, are "Nyquist" plug-ins. These plug-ins are unique to Audacity, and are simple "plain text" files that contain computer code written in a computer language called "Nyquist".
Instructions for installing Nyquist plug-ins are here:
Windows: http://manual.audacityteam.org/man/inst ... st_install
Mac: http://manual.audacityteam.org/man/inst ... st_install
Linux: http://manual.audacityteam.org/man/inst ... st_install
1000Words
Post by 1000Words » Sat Dec 09, 2017 8:37 pm
Thank you so much Steve!
bribri
Post by bribri » Wed Jan 31, 2018 11:14 am
Hi, I am looking for help using De-esser with Audacity (2.1.3).
The reason is that I am beginning a podcast and have a lisp where I emphasise the 'S'.
I am not very tech-savvy so please can you reply in layman's terms!
I believe I have attempted everything correctly and received the below message...
My current make and model of Mac is below...
Please let me know if you require anymore information and I thank you in advance for any assistance. I'll check back for any replies.
Post by steve » Wed Jan 31, 2018 2:08 pm
bribri wrote: I believe I have attempted everything correctly and received the below message...
You need to "install" the plug-in.
Instructions for macOS are here: http://manual.audacityteam.org/man/inst ... st_install
bribri
Post by bribri » Wed Jan 31, 2018 2:51 pm
Hi,
I did exactly this "To install new Nyquist plug-ins, place them in Audacity's "Plug-Ins" folder at ~/Library/Application Support/audacity/Plug-Ins." and placed it in this folder. I then click the DeEsser.ny file and get the first image pop up...
Apologies if i'm missing something glaringly obvious but I'm completely lost here!
Post by kozikowski » Wed Jan 31, 2018 3:11 pm
Once you place the file in the Plugins folder, close everything back out to the application. Don't try to launch it.
In Audacity, Effects > Add/Remove Plugins. You should be able to find it and activate it. I've been known to select them all and install everything.
From there, open your show and apply it.
Post by kozikowski » Wed Jan 31, 2018 3:22 pm
Post back if you get stuck.
msputman
Post by msputman » Sat Feb 03, 2018 12:32 pm
Sorry very frustrated - I can't get the De-Esser to show up under plugins. I followed the links you posted above about how to install .ny plugins - when I navigated to Library/Application Support/audacity there was no Plug-Ins folder at all.
I wound up copy pasting the De-Ess and De-Click .ny files into that folder and then tried all the folders under library/audio/Plug-Ins as well - no luck.
Ultimately I got so desperate I created the Plug-Ins folder under library/application support/audacity with no luck.
Any advice from anyone? Would really appreciate it.
