Updated De-Clicker and new De-esser for speech
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Re: Updated De-Clicker and new De-esser for speech
Post by steve » Wed May 12, 2021 2:40 pm
Firstly, I don't use this plug-in myself, but I think the idea of the "isolate changes" feature is that you would run that on a duplicate copy of the track (or part of a track) so that you can see more easily what exactly the effect will remove when you apply it normally.
You can make a duplicate copy by:
1. Select the audio that you want to copy
2. "Ctrl + D" (or "Edit menu > Duplicate")
mediamdpodcast
Post by mediamdpodcast » Mon Jun 07, 2021 12:05 am
I'm having trouble with the De-Clicker crashing if I try to process over an hour of audio at once. Is it possible to fix this?
Post by steve » Mon Jun 07, 2021 12:11 am
Paul wrote in the first post:
I treat typically no more than a half hour at once.
I'd suggest that you take that as a recommendation, though you could try asking him to fix it. He can be contacted via the Audacity developer's mailing list (see: https://www.audacityteam.org/contact/mailing-lists/)
