Updated De-Clicker and new De-esser for speech
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Kyula
Re: Updated De-Clicker and new De-esser for speech
Post by Kyula » Mon Jan 18, 2021 8:26 am
Hey thanks!
Looks (& and sounds) great, but with the desibilator it seems to sound like I lisp a bit, doesn't it? (which I acutally did pretty much when I was younger)
at which step in my audio processing order should these steps be implemented?
and should I leave out some of the steps I am doing right now?
Trebor
Post by Trebor » Mon Jan 18, 2021 5:11 pm
... the desibilator it seems to sound like I lisp a bit, doesn't it? ...
All de-essers do that if you set the threshold too low.
RMS is just a suggestion for the threshold, a starting point.
If it's causing a lisp, raise threshold (in 1dB steps) until the lisp goes away.
odevroed
Operating System: Linux Fedora/RHEL
Post by odevroed » Wed Feb 10, 2021 4:58 pm
Hi,
I just installed the de-esser on my linux system (version 2.3.3) and each time I apply th plugin, audacity crashed. However, the de-clicker works fine. In both cases, I used the defaults.
Does anybody have the same experience and what can I do about it?
jademan
Forum Crew
Post by jademan » Thu Feb 11, 2021 12:53 pm
Windows guy here; I'm hoping that a linux guru will come around and post a comment shortly. While we are waiting, does this still happen after you reboot your machine?
Trebor
Post by Trebor » Thu Feb 11, 2021 1:58 pm
I just installed the de-esser on my linux system (version 2.3.3) and each time I apply th plugin, audacity crashed ...
Try the desibilator version of that plug-in: it has different default settings.
Ken Clark
Post by Ken Clark » Sat Feb 27, 2021 9:43 pm
Maybe a silly question, but I am not seeing how to install these plug-ins?
Post by steve » Sat Feb 27, 2021 10:03 pm
These are "Nyquist plug-ins". Installation instructions for Audacity on Windows are here: https://manual.audacityteam.org/man/ins ... st_install
Ken Clark
Post by Ken Clark » Sat Feb 27, 2021 11:44 pm
Thank you
Antoine
Post by Antoine » Sat Mar 06, 2021 5:15 pm
Oh, thank you a lot, Paul, for these plugins! What a good work you made!
danitadrum
Post by danitadrum » Sun Mar 21, 2021 9:16 pm
What app do I need to install in order to open the DeClicker and DeEsser onto
my mac computer? Also can I use the plug-ins on the new Macbook Pro M1?
