Updated De-Clicker and new De-esser for speech
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Gibbz
Operating System: Linux Debian
Re: Updated De-Clicker and new De-esser for speech
Post by Gibbz » Thu May 28, 2020 11:59 pm
Ok thanks! Ill keep an eye out for the new release :D
WeaverGrace
Post by WeaverGrace » Fri Jun 05, 2020 8:41 pm
Paul L wrote:
Thu May 29, 2014 6:27 pm
Here are the latest improvements to the plug-in I am developing for filtering out of wet mouth noises and clicks from my narrations. I also present a de-esser using similar methods that fell out as a by-product.
These are amazing! I've been playing with the settings, and really appreciate them for the whistles and clicks that get buried in some of my words. I'll still Zoom In and Delete or Repair most of my noises, but for the ones that are difficult to find and isolate, these Effects work so well! Thank you!
Post by kozikowski » Sat Jun 06, 2020 3:32 pm
There's a couple of tricks to the DeEssing business.
Analyze > Plot Spectrum. Pick as high a Size as the system will allow. 16000 is good.
Low pitch tones on the left, high pitch tones on the right.
That blue haystack on the right is Essing.
Normal voices don't do that. That's the drilling teeth sound. The hump goes from roughly 4000Hz to 10000Hz, so those are the numbers I put in the DeEsser. Accuracy isn't that important.
And poof. No more blue haystack and no more essing.
This works particularly well after you audiobook master because then the volume of the performance is fixed and you don't have to go chasing after it with the DeEsser Threshold setting. Last I used it, I picked -30.
MoPro
Post by MoPro » Tue Jul 14, 2020 3:30 am
Hey ... I'm excited to try this De-esser you're all are talking about ... but I can't find it anywhere!
I have Audacity 2.3.2 and 2.4.2.
I've looked in all the drop downs.
I've been to the Installing Nyquist plug-ins page here:
https://manual.audacityteam.org/man/ins ... ndows.html
And the ''List of available plug-ins'' here:
https://wiki.audacityteam.org/wiki/Down ... g-ins#list
I can't find ''De-esser'' anywhere.
What am I missing?
Thanks ...
Trebor
Post by Trebor » Tue Jul 14, 2020 3:56 am
I can't find ''De-esser'' anywhere ...
It is attached to the bottom of the first post of this thread ...
viewtopic.php?f=42&t=79278
TacoProxy
Post by TacoProxy » Sun Jul 19, 2020 2:49 am
Holy cow. I had to sign up just to say THANK YOU. You have saved me so much time with this. Once again THANK YOU SO MUCH.
fameshow1
Operating System: macOS 10.11 El Capitan
Post by fameshow1 » Thu Aug 20, 2020 1:37 am
The De-Esser doesn't open directly from the link provided. What's the name of the website,maybe I can downloaded from there. Thank you very much, Paul!!!
Post by steve » Thu Aug 20, 2020 10:11 am
This is the website.
The download links are near the bottom of this post: viewtopic.php?p=245549#p245549
These are "Nyquist Plug-ins". Instructions for installing Nyquist Plug-in on macOS: https://manual.audacityteam.org/man/ins ... st_install
Trebor
Post by Trebor » Thu Sep 03, 2020 10:16 pm
[In Arnold Schwarzenegger voice]
Behold ... the Desibilator, (attached).
This 'desibilator' plugin is Paul Licameli's 'DeEsser.NY' just with different default-settings, different slider-ranges, & has tips added to the UI.
Previously the default frequency-range was not wide enough: it stopped at 8kHz, (now 13kHz).
Previously the "number of bands" slider went up to 1000 :shock: , when <5 bands is generally sufficient, and >50 will freeze/crash Audcaity.
So this variant of Paul-L's de-esser plugin is more likely to give first-time-users what they want, quickly, without crashing Audacity.
desibilator.ny
A tweaked version of Paul Licameli's 'DeEsser.NY'
(56.03 KiB) Downloaded 280 times
utom
Post by utom » Wed Oct 28, 2020 4:03 pm
How to use the "Debu Labels (short)" or "Debug Labels (long)" feature?
Is there any label format that is assumed in that functionality?
Is there a way to generate those labels automatically?
Is there any user guide that explains details?
