Karaoke, Rotation, Panning & more
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Starkiller2
Re: Karaoke, Rotation, Panning & more
Post by Starkiller2 » Wed Jul 15, 2015 7:15 pm
All you have to do is importing it, select all (Ctrl+a or similar), call the plug-in and hit enter.
The settings should be "Remove Vocals", Strength 1.0, low-cut 120, high-cut 9000 or alike
Exactly what I did. Remove vocals doesn't work (I also tried with your last excerpt)
Robert J. H.
Post by Robert J. H. » Thu Jul 16, 2015 3:05 am
What operating system are you working on?
Your (somewhat terze) description indicates that the audio isn't processed at all. That's a very unusual behaviour and there are only a few reasons that seem plausible, such as:
1. Audacity is paused but you would not be able to call the effect GUI in this case.
2. Wrong selection; it's too short, somewhere without vocals etc. That's why I said "Ctrl+a", use Cmd if you're on a Mac.
3. Processing is aborted manually. The effect takes some time to process and one has to wait for it to finish. Do you see the progress bar?
4. Abortion due to lack of memory. Seems highly improbably but nevertheless possible. Normally, Audacity would simply hang in this case.
5. An error occurs during execution. As written earlier, try the debug button instead of the OK button and post the output.
6. The audio isn't stereo anymore due to some problem with the importer. Choose the "Analyze" action from the plug-in and tell me what the correlation value amounts to.
7. Some forbidden character within the plug-in file - not likely to occur in two different versions of the plug-in though.
In summary, we need
- Operating system
- Screen shot before plug-in call
- Text from the debug output.
- Correllation value from "Analyze".
This should suffice for now.
Cheers
Robert
Starkiller2
Post by Starkiller2 » Thu Jul 16, 2015 1:05 pm
ok, let's see:
I'm on Linux 64-bit (Ubuntu and Mint). The plugin doesn't work on neither of the two distros.
On both plugin versions I'm using the default settings: for the "old" version Remove Vocals, Return Audio and Effect parameter 0.0; for the "slim" version Remove vocals, strength 1.0. On both plugin versions the lower and higher frequency cut points are 120hz and 9000hz
1. I'm not sure what you mean by Audacity paused but I can call the effect and change the settings so I guess this is ruled out?
2. I selected all of the clip you gave me, as seen in this picture:
3. Yes, I see the progress bar. It takes about 25 seconds to complete for the last clip
4. Audacity has never crashed or frozen while applying the effect
5. If I use the "old" version I get "Peak ratio Input:Output for the first 200000 samples: 0.944515". If I use the "slim" version I get nothing, absolutely nothing.
6. Pan position: 0.171831, left and right channels correlated by about 65% (it says it's a good value)
Tell me if you need any more info
Thank you
Robert J. H.
Post by Robert J. H. » Thu Jul 16, 2015 3:16 pm
Starkiller2 wrote:ok, let's see:
Thank you
Ok, so it is actually all green.
I have no idea what's the matter.
I hope that one with a Linux system (e.g. Steve) can redo the test and confirm that it is a Linux problem.
Does the old effect (Vocal Remover) or the "Classic" setting work?
The Audacity version 2.1.1 makes use of the newest Nyquist library, thus it is possible that it will work then.
Robert
Starkiller2
Post by Starkiller2 » Thu Jul 16, 2015 3:52 pm
Steve Daulton's Vocal Remover (which inverts one channel and mixes the two as mono) works.
Not sure what you mean by "classic setting".
I'm also waiting for 2.1.1 to come out
Post by steve » Thu Jul 16, 2015 3:57 pm
Robert J. H. wrote:I hope that one with a Linux system (e.g. Steve) can redo the test and confirm that it is a Linux problem.
Testing with This is the result:
result.flac
(1.89 MiB) Downloaded 81 times
In short, it works fine here. I've no idea what Starkiller2 is doing wrong. Will test on an older version of Audacity shortly.
Starkiller2
Post by Starkiller2 » Thu Jul 16, 2015 3:59 pm
Maybe I'm using the "wrong" Audacity version? (2.1.0)
Post by steve » Thu Jul 16, 2015 4:07 pm
Tested (same procedure as in previous post) with Audacity 2.1.0 alpha Feb 8th,
Same result - works fine.
Post by steve » Thu Jul 16, 2015 4:15 pm
Starkiller2 wrote:If I use the "slim" version I get nothing, absolutely nothing.
What do you mean "you get nothing"?
Does the waveform disappear?
or do you mean that you get no noticeable change from the original pre-processed track?
Starkiller2
Post by Starkiller2 » Thu Jul 16, 2015 4:27 pm
I mean if I click on debug instead of OK (as Robert told me to do), I get no text in the nyquist output box
