I've finally found some time to test this (rather than just read Steve's outline description and instructions).
My initial thoughts (before I tested it and read the associated thread where we are discussing similar
http://forum.audacityteam.org/viewtopic ... 5&start=30 ) were
1) First the negative - it stops this just being a very simple fade-out with no controls or parameters at all (for me as a non-geek-simpleton it was ideal) - the programmable aspect forces me to think about it.
2) On the plus side - it looks as they we can counter the argument that surfaced on one of the discussions (dev email ?) that it is not really a Professional fade - the increased power given to the user will probably lift it up into the pro-league.
3)I assume that the default will be exactly the same as the existing early implementation Pro-Fade - is that correct?
To address theses points post-testing and post-reading the associated Musical Fade In effect thread)
1) Assuming that we implement such that only Pro-Fade-Out
(and possibly Pro-Fade-In) is distributed with the Audacity distribution and that the Pro-Fade-Configure is available as an optional download for expert and power users - then this will remain as a nice simple easy-to-use one-click effect for the average user (and the newbies). Having said that I think I could live with making the configurator part of the release and not an optional download - I have mixed thoghts about this - we would need to think carefully about the documentation so that it doesn't scare-off potential users thinking it's too complicated.
2) With the configuration tool it is certainly looking much more like a "professional fade" justifying it's name (a name that also hints at its pro-grammability as Steve points out elsewhere)
3) I am unclear as to wheteher or not I get exactly the same effect out of the box as the old Pro-Fade. My OOTB settings dor the generator tool are S-Curve (which I thinks is correct) - but the Sweep Filter is set to 0 Hz (and I'm not sure that is correct to match the original Pro-Fade).
4) I had a bit of trouble finding the congurator after I loaded it into the plugins folder for my test-bed Audacity. It appears in the
Generate menu which is a totally inappropriate place for it. I initially looked for it under
Effect menu then had a look in
Preferences, both of which seem somewhat logical to me - but I certainly wouldn't expect to look for it under
Generate
5) Am I assuming correctly that Gale should be able to use this effect and the configurator to create handy one-click fades for his favourite Cross-Fade-In and Cross-Fade-Out.
6) Am I assuning correctly that if we did have the Musical Fade in (or Pro-Fade-In - and I prefer this nomenclature) then the configurator would expand to have an additional separate curve-type for the fade-in (and a separate sweep filter control)?
I am more than slightly worried that we are now discussing the Pro-Fades in at least 3 different forum threads:
a) here
b) Musical Fade:
c) the poll:
http://forum.audacityteam.org/viewtopic ... 20&t=69252
But it's looking good to me - just a tiny bit more polish needed
Peter
