Cross Fade In / Out (upgrade?)
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Post by steve » Tue Oct 23, 2012 7:40 pm
The upper track shows a crossfade of white noise using the current Audacity ""Cross Fade In" and "Cross Fade Out" effects.
The lower track shows the same noise being crossfaded using an alternative "Equal Power" curve (For the technically inclined it uses a "1/4 cycle Cosine" curve).
You will notice that the RMS level (pale blue) is pretty well constant throughout in both cases.
The most obvious difference is that the second track has a more gradual transition into and out from the cross-fade region. This is because the currently shipped version has a more abrupt start to the fade-in and a more abrupt end to the fade-out than the alternative version.
What difference does it make to the sound?
That is the $65,000 question.
Try it yourself with some real audio recordings and find out.
Here is a pair of plug-ins for "Version 2" of the Cross Fade In and Cross Fade Out effects. They can be installed in the normal way and will appear next to the normal shipped versions in the Effect menu.
crossfadein.ny
(203 Bytes) Downloaded 210 times
crossfadeout.ny
(223 Bytes) Downloaded 203 times
The difference is quite subtle.
Can you tell the difference?
Do you have a preference?
yulac
Re: Cross Fade In / Out (upgrade?)
Post by yulac » Tue Nov 06, 2012 3:06 am
is confuse , we have tp compair but you cannot becoz files alrsady exist. anyay i can try each in different versionb of audicity
Post by Gale Andrews » Tue Nov 06, 2012 3:54 am
yulac wrote:is confuse , we have tp compair but you cannot becoz files alrsady exist. anyay i can try each in different versionb of audicity
You can rename the two files before you put them in the Audacity plug-ins folder, or alternatively let your operating system choose a new name when you paste them in.
Post by Gale Andrews » Tue Nov 06, 2012 4:18 am
OK prompted by yulac I tried them.
You probably won't like my answer because though I like Cross Fade In and Cross Fade Out as shipped, I don't usually use them to make a cross fade - I prefer a linear cross fade because I often like to lose a little volume in the transition. But cross fading white noise or music with Steve's new Cross Fade In and Cross Fade Out, I think the result is a bit more continuous or smooth than with the shipped effects (if equal power is the aim). I doubt you would notice the difference without side-by-side comparison.
I much prefer the extra force at the start of the shipped Cross Fade In/end of the shipped Cross Fade Out. I like to have a fade that sounds as if it is not done electronically but as if it was an acoustic performance. The attached is typical of something I may want to fade out - a two-second final note of a choir in a church followed by half a second of reverb, at which point I cut it. In reality, applause starts where I cut it and the reverb goes on for another half second. The shipped Cross Fade Out sounds much more natural for what I want, Steve's replacement has very little volume right at the end and is clearly an "effect".
vilar.wav
Choral die-away cut just before applause starts
(429.2 KiB) Downloaded 122 times
waxcylinder
Post by waxcylinder » Tue Nov 06, 2012 12:38 pm
Steve,
how does this relate to your other plugin Cross-fade-classic (which I find works very well - and is simple to use)?
Peter.
Post by steve » Tue Nov 06, 2012 12:50 pm
Gale Andrews wrote:You probably won't like my answer
I asked for opinions so I'm perfectly happy (delighted) to hear anyone's opinion. :)
Gale Andrews wrote:I prefer a linear cross fade because I often like to lose a little volume in the transition.
I'll keep that in mind when I re-look at (real) crossfade effects.
Gale Andrews wrote:cross fading white noise or music with Steve's new Cross Fade In and Cross Fade Out, I think the result is a bit more continuous or smooth than with the shipped effects (if equal power is the aim).
The aim of these Cross Fade In/Out effects is to produce a transition when crossfading that is as "smooth" as possible. I'm glad that you agree that these fades give the desired effect.
Gale Andrews wrote:I much prefer the extra force at the start of the shipped Cross Fade In/end of the shipped Cross Fade Out. I like to have a fade that sounds as if it is not done electronically but as if it was an acoustic performance. The attached is typical of something I may want to fade out - a two-second final note of a choir in a church followed by half a second of reverb, at which point I cut it. In reality, applause starts where I cut it and the reverb goes on for another half second. The shipped Cross Fade Out sounds much more natural for what I want, Steve's replacement has very little volume right at the end and is clearly an "effect".
Thanks for the comment.
I wouldn't use this "Cross Fade Out" effect for performing a fade out on that audio either, but that is not what the "Cross Fade Out" is designed for.
I probably would use this Cross Fade Out effect if I was cross-fading that audio with another piece of music.
vilar-mix.flac
Cross Fade example
(523.51 KiB) Downloaded 136 times
Post by steve » Tue Nov 06, 2012 1:20 pm
waxcylinder wrote:how does this relate to your other plugin Cross-fade-classic (which I find works very well - and is simple to use)?
These fades could be used in a new version of Cross-Fade-Classic.
Generally I prefer the sound of a crossfade made with these fade types than what Cross-Fade-Classic currently uses or to the linear fades or the currently shipped Cross Fade In/Out, though for power users it would be nice to offer a choice). This is a "classic" shape for crossfades so it would be highly appropriate for the "Classic-Cross-Fade" effect.
For a one click cross-fade effect (such as the "Classic") the choice of fade type is obviously important.
For a crossfade effect that has an interface, then the "generally works best" (whatever that might be) should be the default.
