EZ-Patch
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
EZ-Patch
Post by steve » Wed Dec 07, 2011 10:57 pm
Download EZ-Patch (read the instructions below first!)
EZ-Patch.ny
(2.17 KiB) Downloaded 4136 times
I have an audio track with a bad glitch on the right channel (shown selected)
glitch highlighted
The glitch is too big and bad for the Repair tool.
It can be moderated using the "Pop Mute" effect, but that will not remove the damage, it'll just make it a bit smaller.
The best way to repair would be to make a "patch" by copying and pasting a similar piece of audio and cross-fading rapidly from one to the other. The audio immediately after the glitch would be suitable for making the patch, but it's quite a fiddly job to make a good job of patching.
Time for "EZ-Patch".
Here's I've selected the glitch and allowed a little room either side for a rapid cross-fade, then extended the selection to the right fare enough to create the patch.
Doing this manually would require multiple steps, but with EZ-Patch all that is needed is to select, then click OK.
and the result:
patched
And here's the before and after:
before-after.wav
(625.2 KiB) Downloaded 1481 times
Reason: Make the download link more prominent and move it to the top
Learn more about Nyquist programming at audionyq.com
billw58
Re: EZ-Patch
Post by billw58 » Thu Dec 08, 2011 3:55 pm
Brilliant, yet again!
It's now in my plug-ins folder. Next time I have an LP recording with a real big glitch (too big for ClickRepair to deal with) I'll give it a try.
-- Bill
Re: EZ-Patch
Post by steve » Thu Dec 08, 2011 10:36 pm
Thanks for the feedback Bill.
Frediano
Re: EZ-Patch
Post by Frediano » Wed Dec 21, 2011 10:13 pm
Hi,
I have about the same problem, but don't need the fading. How can I - for any purpose - select one, or part of one channel of a stereo file?
Tks - Frediano
Re: EZ-Patch
Post by steve » Thu Dec 22, 2011 12:20 am
Frediano wrote:How can I - for any purpose - select one, or part of one channel of a stereo file?
Click on the name of the track and from the drop down menu select "Split Stereo Track". You can then work on the two audio channels independently.
Frediano
Re: EZ-Patch
Post by Frediano » Thu Dec 22, 2011 10:50 am
Thanks a lot. Probably the only item on which I didn't click before. frediano
Cwluc
Re: EZ-Patch
Post by Cwluc » Sun Feb 05, 2012 1:31 pm
You are a miracle worker. Thank you!
Re: EZ-Patch
Post by steve » Sun Feb 05, 2012 2:40 pm
Thanks for the feedback Cwluc. Glad you like it.
buja
Re: EZ-Patch
Post by buja » Mon Nov 18, 2013 7:38 am
Hi Steve,
I agree with Cwluc...
I just started using Audacity today and I'm taking out these loud nasty pops on a recording of a violin from the 50s and it sounds great!
I have a question about the Cross-Fade Overlap setting...
It's a percentage...but a percentage of what? The total time of the selection? Does the percentage to the total crossfade on both sides or does each side split the percentage.
Sorry for the newbie questions.
EZ-Patch is great!
Re: EZ-Patch
Post by steve » Mon Nov 18, 2013 11:50 am
Thank buja.
buja wrote:I have a question about the Cross-Fade Overlap setting...
It's a percentage of the "patch" (see the second picture in the first post). In other words, a % of half of the selection.
If set to 50%, the crossfade at the beginning of the patch will meet the crossfade at the end of the patch.
Usually you would want the crossfade fairly short - it's there so that the transitions into and out of the "patch" are smooth.
Does that make sense?
