Cross-Fade (revisited)
I decided to have another go, starting from scratch, at making a replacement for the "Cross Fade In" and "Cross Fade Out" effects.
To use this plug-in, the tracks to be cross-faded will be placed end-to-end on the same track.
A selection is then made that includes the end of the first track and the start of the next track.
When applied, the Cross Fade effect applies a fade out to the audio at the beginning of the selection and a fade-in of the audio at the end of the selection. The fade-out and fade-in are then overlapped automatically to create the cross-fade.
The effect includes a couple of other features but I have aimed to make it as simple and easy to use as possible.
Obsolete version: Click here to download the current version
Reason: update link to current version of plug-in
Re: Cross-Fade (revisited)
Thanks Steve! Major improvement. Some thoughts...
Currently, Cross Fade In/Out are useless to me.
I like the idea of combining cross fade into a single dialog, but...
From a GUI standpoint:
While discoverable, the "Show Help" in the "Select Action" drop down is not user friendly; make it a button--there is lots of room on the dialog. Also not user friendly, when you do select "Show Help" you must then click "OK" to view Help and this is a "destructive" action (the Cross Fade dialog closes). The help dialog should be independent of the fade dialog (but should close with the fade dialog). More unfriendly, the "help" action is sticky so after clicking OK and reading and closing the help dialog, when you re-open the CF dialog "Show Help" is the selected default.
When either In or Out are selected as solo actions the "Fade Length"... stuff should be ghosted or gone.
I realize the Nyquist GUI builder is sparse and these may not be readily changed.
Functionality
I would extend the ability of the function by adding a "center" so that when xFading the fade-in and fade-out don't have to be the same length.
While I realize that the concept of this is a "destructive" X-fade, most often, I want a non-destructive version. I know I can do this using Fade Out/In and cut 'n' paste but would like to see this a wrapped up in one Cross Fade effect. The top is my starting point, the middle is the current behaviour, the bottom is what I want to end up with (although the cut 'n' paste can be left to mix & render).
Functionality
I completely agree (hence this "wish list" item: http://forum.audacityteam.org/viewtopic ... 39&t=36639 )Edgar wrote:From a GUI standpoint:
Yes I could add a separate "Help" button, but because the action is "sticky", including "Help" in the "Select Action" menu, the users is pushed to select either, a fade type OR the help screen (which is the correct thing to do). If "Help" was a separate button then the user could select (for example) "Fade In" as their desired action, but not realise that they must also deselect "Show Help".
I can't do anything about the option being "sticky", or the action being "destructive" - these are built into the Audacity Nyquist interface and apply to all Nyquist plug-ins.
Yes, that would be nice too, but again it's a limitation of the Audacity Nyquist interface.Edgar wrote:When either In or Out are selected as solo actions the "Fade Length"... stuff should be ghosted or gone.
I'm not sure what you are getting at there. The bottom picture is not a cross-fade. It is a fade-out followed by a fade-in and can be accomplished with this plug-in by applying a fade-out to the first track and a fade-in to the second track.Edgar wrote:The top is my starting point, the middle is the current behaviour, the bottom is what I want to end up with
Did you notice that the full cross-fade effect (fade-out + fade-in + mix) can be accomplished in one action if both "songs" are on the same track?
I've thought about this, but I think that would be an exceptional case. The common case is that the fade-in and fade-out are the same duration. For the "advanced user", if they want different fade-in / fade-out times they can apply the fade-in first and then the fade-out to separate tracks (similar to how you would do it now, but with the added feature that the fade shape can be a user defined curve).Edgar wrote:I would extend the ability of the function by adding a "center" so that when xFading the fade-in and fade-out don't have to be the same length.
The only really non-destructive way would be to use Envelopes to create the fades, but Audacity Nyquist can not currently access envelope data (another feature request).Edgar wrote:I want a non-destructive version.
To be able to adjust the amount of overlap, the two "songs" could be in different tracks, then the fades are applied but there is no mixing.
I did notice a minor failing of this effect - if the fade time was set to a duration of less than one sample, the effect would fail without error or warning (Audacity Nyquist cannot return zero length sound). It is arguable what should occur in this situation (a zero length cross-fade is not a cross-fade) but how I have decided to resolve this is to give an error if the duration is set as a negative value, and to limit the duration to a minimum of 2 samples (the minimum required by the code for a true cross-fade) if not negative. The new version is attached.
Learn more about Nyquist programming at audionyq.com
- Quality Assurance
- Operating System: Windows 10 / 11
Thanks, Steve. This is just "stupid user" comments because I haven't thought a lot about this.
I thought we wanted "Cross-Fade" with a hyphen given we don't use the more common "Crossfade"? Not that I care as long as we are consistent.
Help says:
Should not "mid-point" in the Help be "midpoint"?
http://en.wikipedia.org/wiki/Midpoint
Then maybe "Strength of fade midpoint" instead of "Curve (increase to boost mid fade)"? I find a second "Curve" concept in addition to shape confusing.
;info line says:
Would the whole cross-fade thing be simpler if we excluded standard fade in and out? I think there are other plug-ins we want to add that can do more advanced fade in/out, and this plug-in is called "Cross Fade". Then we could say "Cross Fade' fades out the first ' x' seconds of the selection and fades in the final ' y' seconds, where 'x' + ' y' is the 'Fade Length' in seconds." Then "Fade Length" in the interface could actually be 10 seconds where there is a selection of at least 10 seconds. I think lots of people will select 5.5 seconds in the waveform, "Fade Length" of 5 seconds and then not understand why there is an error.
Or could there be a default "idiot's fade" where it just cross-fades the selection given to it?
As a general point, the last idea where there were two versions (one for the "popular" cross-fade on one track and another for cross-fade on two tracks) was a bit of a dead-end. But here, there is no mention that a single track or multi-track fade can be made, so people like Edgar used to doing it "properly" on two tracks may not even realise it can be done on one.
Help says:
No need for "," before "or" - was taught as bad grammar when I went to school. Maybe opinions are different now but the Manual would not allow the above."The 'Fade Shape' offers a choice between a simple curve, or an 'S' shaped curve."
;info line says:
Why single-quote 'Cross Fade'?'Cross Fade' fades out the first 'n' seconds of the selection and fades in the final 'n' seconds, where 'n' is the 'Fade Length' in seconds. 'Fade In' and 'Fade Out' act on the entire selection.
- Quality Assurance
That should read "1.3.4" by the way.;; version 3 plug-in (requires Audacity 1.3 or later)
- Quality Assurance
Of course having read your post to the mailing lists, it's much clearer, but I deliberately did not read it until after looking at the plug-in. My point is that "Fade Length" could be taken as the initial length selected for the fade, not the outcome length, which makes the ;info line potentially confusing. "Fade duration" in the Help isn't ideally clear either. Probably it should be "selection to be faded"?Gale Andrews wrote:Then "Fade Length" in the interface could actually be 10 seconds where there is a selection of at least 10 seconds.
I still think there could be a case for "idiot's fade". We're replacing an effect that had no user interaction at all.
Steve:
Some initial comments. I've just started playing with it.
I think the cross-fade length should be eliminated from the dialog, and whatever selection the user has made should be cross-faded. You have to make a selection in order for the effects menu to be enabled. As it stands now, if I select exactly the region I want cross-faded then invoke the effect, I need to enter exactly half the length I have selected. If the length I enter is too long I get an error, if the length is too short audio is deleted. The latter is probably not what the user wants or expects.
Examples (I've set snap-to seconds to keep it simple)
1) Select 4 seconds and ask for a 2-second crossfade This is fine.
2) Select 16 seconds and ask for a 2-second crossfade Audio has been deleted from the middle of the selection. While this might be considered a "feature", I found it annoying and counter-intuitive.
Also, I think users will be more comfortable making a selection by listening then applying the effect than having to think about how many seconds the fade should be. This is already the case for fade out and fade in, so why not make it consistent for cross-fade?
-- Bill
-- Bill
Thanks for the comments Gale.
Fixed.
So "Curve" is the (correct) name of the control and "(increase to boost mid fade)" is a description that I feel describes the function in a simple way for anyone that is unfamiliar with the term (similar to how we have "Q (higher values reduce width)" in the notch filter effect.
The inclusion of Fade-In/Out options allows more advanced users to use fade curves when creating cross-fades "properly" (across two tracks).
It also provides a raised cosine fade-out which is one feature that I find painfully absent in Audacity.
Does that not explain clearly what the error is?
We have to assume that the user may not make the selection such that exactly half of the selection is the end of the first song and that the other (exact) half is the start of the second song. Let's say that the user selects the final 6 seconds of the first song and the initial 4 seconds of the second song. If the "idiot's fade" cross-faded this selection then the fade out would consist of the first 5 seconds of the first song and the fade-in would consist of the final second of the first song, plus the first 4 seconds of the second song. (Audacity Nyquist does not know when audio clips start and end.)
With the current plug-in, for a 5 second fade the user should ensure that at least 5 seconds of each song is selected. The start of the selection should be at the point where they want the first song to start fading out and the selection should end at the point where they want the second song to be fully faded-in.
This is the important concept for this plug-in and is described in the Help screen as:
It is equally valid to apply this effect to two clips in one track, or to two separate tracks. Detailed usage tips are not a practical proposition in the severely restricted Help screen space but, unlike the other included effects, basic usage instructions have been included in the plug-in.
I'm more than happy for the help screen text to be improved, but I've put as much useful information as I could fit into the available space.
On the subject of "help", the Vocoder. Noise Removal and Auto Duck are far from intuitive and could benefit from built-in help.
If this is included in Audacity I think that line can be omitted entirely. If it is only available as an optional plug-in, then I agree that it should say exactly which versions it works correctly on. I've only tested with Audacity 1.3.12 to 1.3.14 so far. Are you saying that it works in Audacity 1.3.4 but not in 1.3.3?Gale Andrews wrote: That should read "1.3.4" by the way.
Personally I'd prefer "Cross-Fade" but I was being consistent with the current "Cross Fade In" and "Cross Fade Out".Gale Andrews wrote: I thought we wanted "Cross-Fade" with a hyphen given we don't use the more common "Crossfade"? Not that I care as long as we are consistent.
Fixed.
Fixed.Gale Andrews wrote: No need for "," before "or"
Fixed.Gale Andrews wrote:Should not "mid-point" in the Help be "midpoint"?
The term "curve" is used on DJ mixers (and several other audio applications) to describe the fade shape. Increasing the "curve" setting causes the fade to be at a higher level for longer than with a linear fade. There are plenty of references to "fader curve" (for example: http://www.rane.com/note146.html )Gale Andrews wrote:Then maybe "Strength of fade midpoint" instead of "Curve (increase to boost mid fade)"? I find a second "Curve" concept in addition to shape confusing.
because I wanted to quote "Cross-Fade" as the name of the effect but was not sure that " would work correctly as an escape character on all platforms, whereas I knew that single quotes work correctly. Are you aware of any plug-ins that use double quotes in the info text? (I'm mid way through reinstalling my OS at present so it's difficult for me to check).Gale Andrews wrote:Why single-quote 'Cross Fade'?
Yes, a little bit, but only as far as it removes some of the functionality.Gale Andrews wrote:Would the whole cross-fade thing be simpler if we excluded standard fade in and out?
Yes there are, but not (currently) included with Audacity.Gale Andrews wrote: I think there are other plug-ins we want to add that can do more advanced fade in/out,
I think that is just as confusing. What that would suggest to me is that the duration of the cross-fade will be 10 seconds, when in fact it will be 5 seconds.Gale Andrews wrote:Then we could say "Cross Fade' fades out the first ' x' seconds of the selection and fades in the final ' y' seconds, where 'x' + ' y' is the 'Fade Length' in seconds." Then "Fade Length" in the interface could actually be 10 seconds where there is a selection of at least 10 seconds.
The current error message will say something like:Gale Andrews wrote: I think lots of people will select 5.5 seconds in the waveform, "Fade Length" of 5 seconds and then not understand why there is an error.
Code: Select all
"Error.
The selection length (5.50 seconds) is too short
for the initial 5 and final 5 seconds to fade.
For a 5 second cross-fade the selection must be
at least 10 seconds."
(also Bill's comment "I think the cross-fade length should be eliminated from the dialog")Gale Andrews wrote:Or could there be a default "idiot's fade" where it just cross-fades the selection given to it?
When 'Cross-Fade' is selected, the fade duration is
determined by the 'Fade Length' setting. For example,
Fade Length = 3 seconds
The first 3 seconds of the selection fade out,
The final 3 seconds of the selection fade in.
The two sections are then overlapped.
In this example the selection must be at least 6
seconds to accommodate both fade sections.
This can be easily covered in the manual - I've already got some screenshots for illustration.Gale Andrews wrote:there is no mention that a single track or multi-track fade can be made, so people like Edgar used to doing it "properly" on two tracks may not even realise it can be done on one.
Right. So the user sloppily selects 10 seconds of audio (as above), then asks for a 3-second fade - 4 seconds of audio will be removed from the middle of the selection. Of the six seconds selected at the end of the first song, the last 3 seconds are removed and then the fade is applied to the remaining last 3 seconds - probably not a deal-breaker. Of the 4 seconds selected in the second song, one second is removed from the start of the song, and the fade is applied to the remaining first three seconds - this is a deal-breaker: you certainly don't want anything removed from the start of the second song.steve wrote:(also Bill's comment "I think the cross-fade length should be eliminated from the dialog")Gale Andrews wrote:Or could there be a default "idiot's fade" where it just cross-fades the selection given to it?
As it stands now this effect would be great for "tightening up" the between-song applause/crowd noise on live recordings. Say there was 30 seconds between two songs and you wanted to reduce it to 3 seconds - just select all the crowd noise and ask for a 3-second fade. 24 seconds are removed from the middle of the selection and the remaining 6 seconds are cross-faded into 3 seconds. Perfect.
For cross-fading songs I think it is less useful. For that I'd prefer something along the lines of the x-fade effect. With the songs on separate tracks you can rehearse the overlap before you apply the fades, and then once you make the selection across the two tracks you know you'll get exactly what you want. The x-fade effect has the limitation that you must apply reciprocal curves to the two fades. For "mix tapes" you may want to fade out the first song and have the second song start cold. Or you may want to leave the natural fade-out of the first song and have the second song fade in quickly. So I'd envision an effect that does "Fade-Out/In" only, and has a few presets for each: e.g. fast, linear, slow, S-curve, cold/slam.
-- Bill
