Reverso
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
Reverso
Post by steve » Wed Oct 19, 2011 7:19 pm
This is a kind of playing backward while playing forward effect.
It's fun, give it a go.
(It's also fairly slow and needs to load the entire audio into RAM, so probably best not to use it on long tracks).
It will probably require a fairly recent version of Audacity 1.3.x to run correctly (probably 1.3.8 or later, but I've only tested on 1.3.12 and 1.3.13)
reverso.ny
(2.08 KiB) Downloaded 502 times
Trebor
Re: Reverso
Post by Trebor » Fri Oct 21, 2011 8:00 am
alternative name jazzifer :) ...
Sax before-after several applications of reverso.mp3
(596.33 KiB) Downloaded 451 times
Re: Reverso
Post by steve » Fri Oct 21, 2011 11:01 am
Lol :D
As I said, it's a "fun" effect.
Winston
Re: Reverso
Post by Winston » Tue Nov 17, 2020 5:07 pm
Well, it is cool. If you combine Reverso with Reverse, you can make a Reverse/Rewind CD like effect... CDs jump back instead of smoothly playing backward. With both being an reverse effect, it was double-negatived to a positive, but reversed like a CD.
That is an interesting effect... When you hold the previous button, it sounded like it was skipping, and Reverso combined with Reverse gives a similar effect, except reverses at normal speed.
But, the effect I am looking for needs to reverse the direction while preserving instruments, and/or the other way, at least somewhat. When you reverse a sound fading out, it fades in. When you invert volume, something similar could happen. Combining the two should sound like the instrumental still sound normal/forward, but notes are played reversed.
