SiP Amplitude Histogram
Share your Audacity/Nyquist plug-ins here, or test drive the latest plug-ins submitted by Audacity users.
After testing a plug-in from this forum, please post feedback for the plug-in author.
msokele
Post by msokele » Fri Feb 12, 2021 11:49 pm
Greetings from Zagreb :-)
New Plug-In for statistical signal analysis displaying Amplitude histogram as well as DC, St.dev and RMS.
On the preview you can see the result of processing the return-to-zero signal with Gaussian noise that I use for teaching at the Zagreb university of applied sciences...
Enjoy :D
Amplitude Histogram.jpg (110.22 KiB) Viewed 499 times
Amplitude Histogram.ny
(3.19 KiB) Downloaded 29 times
Re: SiP Amplitude Histogram
Post by steve » Sat Feb 13, 2021 7:47 pm
A very interesting and unique output method :)
It's a little bit risky using Unicode as Nyquist itself does not support it, but it worked fine for me.
Also it's nice to see someone using SAL :ugeek:
Personally I always use the Lisp syntax (SAL didn't exist when I started learning how to use Nyquist).
One suggestion I would make is to handle the case of long selections (the plug-in crashes if more than 1 million samples are selected). The easiest way to do that would be to use the ;maxlen header (see: https://wiki.audacityteam.org/wiki/Nyqu ... ers#maxlen)
msokele
Post by msokele » Sat Feb 13, 2021 8:41 pm
Thank you Steve!
A lot 😊
Audacity rules 🏆🏆🏆
