Help for simply copy paste a selection.
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Re: Help for simply copy paste a selection.
Permanent link to this post Posted by haute » Sun Mar 04, 2018 10:56 pm
i change to version 4, and dont work. I test 1, 2 ,3 and 4
A curious thing happens, after trying to use the plugin version (it does not work), if I use the Nyquest version, copy the selection of the track from below to the one above.
haute
Operating System: Windows 7
Permanent link to this post Posted by haute » Sun Mar 04, 2018 11:10 pm
Hi, i solve the problem change header type to Generate, and now work fine.
The use of the plugin is to copy the voices of a central speaker track from one language to another language, respecting the background audio to synchronize with the rest of the channels (L, R, LFE, SL and SR)
Thanks so much for the help
Code: Select all
 ;nyquist plug-in
 ;name "Copy-Paste"
 ;type Generate
 ;version 4
(if (not (boundp '*scratch*))
  (progn
    (setf *scratch* *track*)
    (snd-length *scratch* ny:all)
    "") ;Null string return value
  (progn
    (setf rval *scratch*)
    (setf *scratch* '*unbound*)
    rval))
haute
Previous
Return to Nyquist
Who is online
Users browsing this forum: No registered users and 3 guests
