stereo-chorus by Kathy Drye and Roger Dannenberg
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
DERF
Post by DERF » Thu Jun 25, 2015 5:22 am
Hello.
Please, read this code:]
Code: Select all
(defun nyq:snd-tapv (sound offset modulation maxdepth)
  (multichan-expand #'snd-tapv sound offset modulation maxdepth))
(defun delay-tapv (sound maxdelay delay
                            depth rate
                       saturation &optional (phase 0.0))
 (let
  ((modulation
   (sum delay (prod depth (lfo rate 10000.0 *sine-table* phase)))))
    (hp (sum (prod (nyq:snd-tapv sound 0.0 modulation maxdelay)
                   saturation) sound) 10)))
(defun chorus (input-sound &key (delay 0.03) (depth 0.003)
                                (rate 0.3) (saturation 1.0)
                                (phase 0.0))
  (delay-tapv input-sound (+ delay depth)
              delay depth rate saturation phase))
(defun stereo-chorus (input-sound &key (delay 0.03) (depth 0.003)
                                       (rate1 0.3) (rate2 0.1)
                                       (saturation 1.0))
   (sim
       (pan (chorus input-sound :delay delay :depth depth :rate rate1
                    :saturation saturation) .3)
       (pan (chorus input-sound :delay delay :depth depth :rate rate2
                    :saturation saturation :phase 180.0) .7)))
I have write this code
Code: Select all
(abs-env
 (stereo-chorus (osc 56 5) 0.0))
It does not work well. If I modify the value of the argument rate2, the effect applies to 2 channels. The same goes for the argument rate1. Do you understand the reason of this problem?
I have a second question has to put: in this code, the function stereo-chorus calls the function chorus. This function has the same arguments as the function stereo-chorus. On the other hand, when we adjust the value of an argument of the function stereo-chorus, I have the impression that the regulation of the same argument in the function chorus does not seem to contradict the regulation.
My question is thus: How is this way of functioning possible?
I hope that I am understandable.
Beforehand thank you for your help
Reason: fixed code tags
Re: stereo-chorus by Kathy Drye and Roger Dannenberg
Post by steve » Thu Jun 25, 2015 11:54 am
DERF wrote:(abs-env
The final argument (0.0) in your code will be ignored because you have not given a "key-symbol".
See here for how "&key" is used:
http://www.audacity-forum.de/download/e ... ef-143.htm
Example. You could have something like:
Code: Select all
(stereo-chorus (osc 56 5) :delay 0.1 :depth 0.1)
or
Code: Select all
(stereo-chorus (osc 56 5) :delay 0.1)
(where ":depth" will take the default value)
or
Code: Select all
(stereo-chorus (osc 56 5) :depth 0.1)
(where ":delay" will take the default value)
or
Code: Select all
(stereo-chorus (osc 56 5))
(where both ":depth" and ":delay" take the default values).
DERF wrote:This function has the same arguments as the function stereo-chorus. On the other hand, when we adjust the value of an argument of the function stereo-chorus, I have the impression that the regulation of the same argument in the function chorus does not seem to contradict the regulation.
When you call a named function and supply it with arguments, the arguments are passed to the named function.
Taking a really simple example:
Nyquist has a built-in function for summing numbers. The function name is "+". The function takes one or more arguments which must be numbers, and returns the sum of the arguments.
(+ arg1 arg2 ....)
For example:
Code: Select all
(+ 2 3.5)  ; returns 5.5
The argument "2" (which is a numeric value) and the argument "3.5" (another numeric value) are the two arguments that we send to the function "+".
Similarly Nyquist has a built-in function called "-" which subtracts numbers.
Example:
Code: Select all
(- 10.1 2) ; returns 8.1
Now consider this code;
Code: Select all
(setq a 3) ;symbol "a" has the value "3"
(setq b 4) ;symbol "b" has the value "4"
(setq c (+ a b)) ;pass the arguments "a" and "b" to the function "+". The symbol "c" takes the returned value from the function "+".
(print c) ; prints "7"
(setq a 10) ;set the value of "a" to "10"
(setq b 5) ;set the value of "b" to "5"
(setq d (- a b)) ; pass the arguments "a" and b" to the function "-".
(print d) ; prints "5"
Note that in the above example, the value for "c" is still "7" even though we have changed the values of "a" and "b".
When the expression (+ a b) was evaluated, the value of "a" was "3" and the value of "b" was "4".
If we continue the above example:
Code: Select all
(setq c (+ a b))
(print c) ;prints "15"
We have called the function "+" again, and passed it the arguments "a" and "b", but now the values are a=10 b=5, so the expression (+ a b) evaluates to 15.
Does that answer your question?
DERF
Post by DERF » Sun Jun 28, 2015 9:40 am
Hello.
Thank you for these details. Now, it is more understandable.
I have a question to ask. It concerns the body of the function "chorus".
The code is
Code: Select all
I do not understand which calculations Lisp realize, and in which order. Can you explain me the meaning of the code:
Code: Select all
Thank you in advance.
Post by steve » Mon Jun 29, 2015 12:33 pm
The function "delay-tapv" is defined in the code as:
Code: Select all
                            depth rate
 (let
  ((modulation
Look at the parentheses in the first 3 lines an notice that the function has 6 required argument and one optional argument. The required arguments are:
sound
maxdelay
delay
depth
rate
saturation
The optional argument is "phase" and it has a default value of 0.0.
See here for more information about the structure of a LISP function: http://www.audacity-forum.de/download/e ... ef-087.htm
