I just updated to Audacity 2.1.0 (32-bit version running on 64-bit Win7), and all of my Nyquist plugins written in SAL are now completely broken.
As an example, I've placed the following code in my C:\Program Files (x86)\Audacity\Plug-Ins directory as SalSample.ny:
Code: Select all
;nyquist plug-in
;version 3
;type analyze
;name "DarkMorford's SAL Sample"
;action "Analyzing..."
;codetype sal
;debugflags trace
function main()
begin
return "Hello"
end
In previous versions of Audacity, this displays a dialog box with the "Hello" text, followed by an empty debug-output dialog. In 2.1.0, however, I get a Nyquist Output window proclaiming "error: unbound variable - DARKMORFORD", and the main Audacity log offers up "Warning: Nyquist returned NIL". I don't get the "Hello" text box at all.
The problem is also reproducible using the Nyquist Prompt effect. If I enter
in the command dialog, I get no pop-up window and the same "Warning: Nyquist returned NIL" message in the Audacity log. This happens regardless of whether or not the "Use legacy (version 3) syntax" box is checked.
