Hello,
I am looking for a possibilty to invert the envelope of a sound file (y-axis).
So that high amplitudes will be muted and low amplitudes will be amplified.
I tried working with plugins like hyperexp (where every amplitude is muted or amplified to about the same level)
and other Compressor effects but as I am totally new on Nyquist, it is hard to figure in which way i can analyze the envelope and write a function for the inversion of the data.
As far as i understand i need 3 steps.
- Analysing the sound file to get the data of the amplitudes
- Write a function to set new values for each amplitude automatically
- Apply the new values on the sound file to output the inverted envelope
For the first point i tried (linear-to-db signal) but i could not find out in which range the data is output to get the right function for the inversion. For the last point i thougt a (vector) should do it, but as I said Im not really into it.
Anyones got a hint? Guess it would not be very difficult if i was more familiar with Nyquist.
Nyquist plugin for envelope inversion
jensjensen
Re: Nyquist plugin for envelope inversion
Have a look at "Pop Mute". It does something very similar to what you are asking. http://wiki.audacityteam.org/wiki/Nyqui ... s#Pop_Mute
For the first step you need some sort of "envelope follower". That is, to track the amplitude of the input.
A simple way to do that is with the function snd-avg http://www.cs.cmu.edu/~rbd/doc/nyquist/ ... l#index659
For example, if you select a (mono) track and apply the code (using the "Nyquist Prompt" effect):
The first thing that you will notice with this is that the output length will be very much shorter than the selected audio.
What it is doing is looking at the peak level in each successive 100 samples, thus each sample of the output represents 100 samples of the input. If you zoom in on the result you will see that it has the same "shape" (envelope) as the input.
Setting "step" to a larger value will make the envelope smoother as it is then riding over a larger number of samples.
(For a more sophisticated envelope follower, see snd-follow http://www.cs.cmu.edu/~rbd/doc/nyquist/ ... l#index684)
If you invert that (output) signal and add 1.0, it will become like an upside down envelope.
The upside down envelope can then be applied to the original audio as a scaling factor (multiplication factor).
Is that enough to get you started?
Examples below are for mono tracks. The can be expanded to work with stereo tracks later if required, but it is simpler to start with mono tracks.jensjensen wrote:As far as i understand i need 3 steps.
Code: Select all
(setq step 100)
(snd-avg s step step op-peak)
Code: Select all
(setq step 100)
(setf env (snd-avg s step step op-peak))
(setf env (sum 1 (mult -1 env)))
Code: Select all
(setq step 100)
(mult s env)
I'm looking for a program that changes from moment to moment the envelope of a track, preferably with automation: setting the time, beaten, frame = 32 or 64? Already exists?
Are you asking about "envelope inversion"? If not, please start a new topic.overBass wrote:I'm looking for a program that changes from moment to moment the envelope of a track, preferably with automation: setting the time, beaten, frame = 32 or 64? Already exists?
As your question stands, it is not clear what you mean.
