I have an off-brand voice recorder, it only records in 16-bit, 24000Hz sampling rate, wave files. Although it has only 1 mic it records stereo tracks. So I’m speaking and recording my own affirmations on this voice recorder and I’m opening this file in Audacity.
I use script found on this forum to make the affirmations subliminal, this script requires that the sample rate be 44100Hz, so I change the sample rate to that and make the affirmations subliminal but since my voice recorder doesn’t recognize the wave file with 32-bit 44100Hz sample rate, I’m forced down grade it to 24000Hz, but when I do this, the subliminal affirmations are gone.
How can I create affirmation subliminal for 16-bit, 24000Hz which will preserve the transformation from 32-bit 44100Hz?
