Nyquist changed the value: 0.250000 ???
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Mister X
Operating System: GNU/Linux other
Post by Mister X » Mon Mar 22, 2021 9:12 pm
Hi. I m using Pop OS. And these days i figured it out i cant using Noise Gate. I mean i cant use Limiter also. I get "Nyquist changed the value: 0.250000 ". What does it mean? And how can i fix it?
Re: Nyquist changed the value: 0.250000 ???
Post by steve » Mon Mar 22, 2021 9:46 pm
Which version of Audacity?
What exactly do you do that gives that message?
Mister X
Post by Mister X » Tue Mar 23, 2021 6:24 pm
I get this messege.
Post by steve » Tue Mar 23, 2021 6:34 pm
There is currently a bug in Audacity that affects the Noise Gate effect.
The simplest workaround is to set "hold" to zero.
The bug has been fixed for the next Audacity release which we aim to make available as soon as possible (hopefully about a month).
