Bug in Vocal reduction and isolation
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Felipe Zanabria
Operating System: Windows 7
Post by Felipe Zanabria » Sat Mar 20, 2021 12:22 am
Greetings! I experience an error in this effect when executing the functions that do FFT operations. The only functions that work correctly are those that return mono audio, and the analysis function. I have tried a plug-in from a previous version and it also gives me an error. The conclusion I came to is that there is a problem in Nyquist's internal functions. Below I attach the debugging report.
Debug VocalRediso.txt
(150.6 KiB) Downloaded 39 times
Re: Bug in Vocal reduction and isolation
Post by steve » Sat Mar 20, 2021 12:27 pm
For convenience I'm displaying the first part of the error as text:
Code: Select all
error: array index out of bounds - 28
Function: #<Subr-AREF: #07E34018>
Arguments:
  28
Function: #<FSubr-SETF: #07E30028>
Arguments:
  (: OUT I)
  (: WEIGHT (/ (1+ I) 2))
Function: #<FSubr-DO: #07E35028>
Arguments:
  ((I LOW-TRANSITION (+ I 2)))
  ((>= I HIGH-TRANSITION))
  (SETF (: OUT I) (: WEIGHT (/ (1+ I) 2)))
  (SETF (: OUT (1+ I)) (: WEIGHT (/ (1+ I) 2)))
Function: #<FSubr-LET*: #07E32F08>
Arguments:
  ((POWER-SUM (POWER-SPECTRUM MID FS 2)) (POWER-DIF (POWER-SPECTRUM SIDE FS 2)) (WT-EXP (S-EXP (SCALE STRENGTH (DIFF POWER-DIF POWER-SUM)))) (WEIGHT (SHAPE WT-EXP *MAP* 0)) (WEIGHT (SND-SAMPLES WEIGHT NY:ALL)))
  (DO ((I LOW-TRANSITION (+ I 2))) ((>= I HIGH-TRANSITION)) (SETF (: OUT I) (: WEIGHT (/ (1+ I) 2))) (SETF (: OUT (1+ I)) (: WEIGHT (/ (1+ I) 2))))
  (SND-SAMPLES (MULT (SND-FROM-ARRAY 0 1 MID) (SND-FROM-ARRAY 0 1 OUT)) FS)
Function: #<FSubr-COND: #07E33588>
Please give exact steps for how to reproduce this error.
Felipe Zanabria
Post by Felipe Zanabria » Sat Mar 20, 2021 5:17 pm
When opening the effect, select any option. Eliminate vowels, isolate vocals etc, except for the analyze option and those that return mono audio. When applying, you will see that the effect does not process the track. To make sure there is an error, press the debug button.
If you try to run the function analyze, remove vocals to mono, or remove center to mono, the plug-in works fine.
Post by steve » Sat Mar 20, 2021 6:28 pm
I tested with this file:
test.wav
(1.01 MiB) Downloaded 42 times
and applied "Vocal reduction and isolation" with these settings:
and this was the result:
result.wav
(1.01 MiB) Downloaded 44 times
Seems to be working fine.
waxcylinder
Post by waxcylinder » Sun Mar 21, 2021 12:28 pm
See this Forum thread: viewtopic.php?f=46&t=116726&p=420317
and this P1 regression bug that was logged as a result
https://bugzilla.audacityteam.org/show_bug.cgi?id=2706
Vocal Reduction and Isolation most options fail
Peter.
jademan
Forum Crew
Post by jademan » Sun Mar 21, 2021 12:38 pm
Yes. Vocal Removal fails on Windows 10:
Code: Select all
error: array index out of bounds - 23
Function: #<Subr-AREF: #0B1D6FF0>
Arguments:
  23
Function: #<FSubr-SETF: #0B1D3000>
Arguments:
  (: OUT I)
Function: #<FSubr-DO: #0B1D8000>
Arguments:
Function: #<FSubr-LET*: #0B1D5EE0>
Arguments:
Function: #<FSubr-COND: #0B1D6560>
Arguments:
  ((AND MID SIDE) (LET* ((POWER-SUM (POWER-SPECTRUM MID FS 2)) (POWER-DIF (POWER-SPECTRUM SIDE FS 2)) (WT-EXP (S-EXP (SCALE STRENGTH (DIFF POWER-DIF POWER-SUM)))) (WEIGHT (SHAPE WT-EXP *MAP* 0)) (WEIGHT (SND-SAMPLES WEIGHT NY:ALL))) (DO ((I LOW-TRANSITION (+ I 2))) ((>= I HIGH-TRANSITION)) (SETF (: OUT I) (: WEIGHT (/ (1+ I) 2))) (SETF (: OUT (1+ I)) (: WEIGHT (/ (1+ I) 2)))) (SND-SAMPLES (MULT (SND-FROM-ARRAY 0 1 MID) (SND-FROM-ARRAY 0 1 OUT)) FS)))
  (T NIL)
Function: #<Closure-STEER: #0AE75A70>
Arguments:
  #(3.89424 3.57582 1.46559 2.75328 2.74745 1.51856 3.56544 0.0150764 3.87915 -1.44129 3.61418 -2.71268 2.76197 -3.58549 1.54268 -3.87379 0.0588427 -3.62878 -1.44959 -2.806 -2.69551 -1.53953 -3.58989 -0.0847347 -3.91664 1.44382 -3.63051 2.73572 -2.84392 3.5957 -1.56319 3.96983 -0.0587764 3.68196 1.43973 2.8503 2.79174 1.60402 3.66819 0.0329819 4.01182 -1.49803 3.77702 -2.83763 2.88771 -3.79688 1.60779 -4.10908 0.0423806 -3.86218 -1.59733 -2.99722 -2.93639 -1.60603 -3.9202 -0.0288085 -4.3008 1.66348 -3.97205 3.11953 -3.11949 4.0686 -1.68261 4.51809 0.032914.....etc......-0.00348186 0.00144386 -0.00375652 1.74344e-06 -0.00348186 -0.00144422 -0.00266194 -0.0026536 -0.0014354 -0.00348067 -9.42871e-06 -0.00376272 0.00144267 -0.00346947 0.00265908 -0.00266695 0.00346994 -0.00143504 0.00376797 -9.16421e-07 0.00346756 0.00143445 0.00265956 0.00266838 0.00144529 0.00346971 -9.07108e-06 0.00376034 -0.00143576 0.00347996 -0.00266027 0.00264931 -0.00348258 0.00144112 -0.00375605 -2.55182e-06 -0.00348115 -0.00144768 -0.0026598 -0.00265265 -0.00143194 -0.00348163 -5.07385e-06 -0.00376272 0.00144696 -0.0034709 0.00266242 -0.00266719 0.00347233 -0.0014329 0.00377274 1.55717e-06 0.00347376 0.00143671 0.0026598 0.00267005 0.00144386 0.00347233 -9.56468e-06 0.00376463 -0.00143695 0.0034852 -0.00266123 0.00265551 -0.00348425 0.00144434 -0.00375664)
  #<Object: #0B146BD0>
Function: #<FSubr-IF: #0B1D7F90>
Arguments:
  ARGUMENT2
  (FUNCALL FUNCTION (SND-FFT SOUND LENGTH SKIP WINDOW) ARGUMENT2)
  (FUNCALL FUNCTION (SND-FFT SOUND LENGTH SKIP WINDOW))
Function: #<Subr-SEND: #0B1D8B30>
Arguments:
  #<Object: #0B1464F0>
1>
