dual amplify
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Bloodrock
Operating System: Linux Mint
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 6:44 pm
i must be doing something when sending a reply with code thought you hit code then under it add code or what do i need to do
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 6:48 pm
ok guess it went thru lots of times i get the 503 error when replying or posting
Re: dual amplify
Post by steve » Wed Jul 15, 2020 6:48 pm
Bloodrock wrote:
Wed Jul 15, 2020 6:41 pm
To use "code" tags:
  1. Click the "</>" button. That will add:
    [code][/code]
  2. Paste your code between the two code tags, like this:
    [code]
    Code goes here...
    [/code]
Re: dual amplify
Post by steve » Wed Jul 15, 2020 6:56 pm
Bloodrock wrote:
Wed Jul 15, 2020 6:07 pm
this is what i tryed
Pretty close for a first attempt :)
The ";action" and ";info" headers are no longer used, so they can be left out.
I'd suggest replacing these two lines:
Code: Select all
(setf left-gain 0.5)
(setf right-gain 0.8)
with controls:
Code: Select all
;control left-gain "Left gain" float "" 1 0 2
;control right-gain "Right gain" float "" 1 0 2
Then you just need the processing part:
Code: Select all
(vector
  (mult (aref *track* 0) left-gain)
  (mult (aref *track* 1) right-gain))
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 9:01 pm
ok getting farther still is not adjusting volume just does a nyquist returned the value 0.8000000
Code: Select all
;nyquist plug-in
;version 1
;type process
;name "Amplify both channels..."
(setf right-gain 0.5)
;;control left-gain "Left gain" int "" 1 0 2
;;control right-gain "Right gain" int "" 1 0 2
(vector
  (mult (aref *TRACK* 0) left-gain)
  (mult (aref *TRACK* 1) right-gain))
after running get this
error: unbound variable - *TRACK*
if continued: try evaluating symbol again
1>
Re: dual amplify
Post by steve » Wed Jul 15, 2020 9:12 pm
;version 1 is for ancient versions of Audacity.
For current versions of Audacity, plug-ins should be set to ;version 4.
Also, you don't need the lines:
Code: Select all
because left-gain and right-gain are set by the controls:
Code: Select all
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 9:59 pm
ok that did the trick thanks for all the help working like i wanted
Felipe Zanabria
Operating System: Windows 7
Re: dual amplify
Post by Felipe Zanabria » Fri Dec 18, 2020 5:55 am
I have tis plug-ing for you:
Code: Select all
 ;nyquist plug-in
;version 4
;type process
;name "Amplify channels by percent"
;action "Amplifying channels..."
;info "Amplify channels independently by percent
;control left-gain "Left channel amplification" int "Percent" 100 0 100
;control right-gain "right channel amplification" int "Percent" 100 0 100
(setf left-gain (/ left-gain 100.0))   ;Amplification amount for left channel
(setf right-gain (/ right-gain 100.0))  ;Amplification amount for right channel
(vector
