dual amplify
Using Nyquist scripts in Audacity.
Post and download new plug-ins.
Bloodrock
Operating System: Linux Mint
dual amplify
Post by Bloodrock » Wed Jul 15, 2020 1:45 pm
I am looking for amplify that lets me adjust the volume for both left and right channels either by db or percent.
has to have separate volume controls for each track that can be locked or unlocked to adjust one or the other.
if anyone has or knows or can write one please give me a shout
thanks
Re: dual amplify
Post by steve » Wed Jul 15, 2020 2:06 pm
Code: Select all
;version 4
(setf left-gain 0.5)   ;Amplification amount for left channel
(setf right-gain 0.8)  ;Amplification amount for right channel
(vector
  (mult (aref *track* 0) left-gain)
  (mult (aref *track* 1) right-gain))
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 4:15 pm
thanks steve it works but not quite what i want here is a screenshot of what i am looking for
DVDdoug
Forum Crew
Re: dual amplify
Post by DVDdoug » Wed Jul 15, 2020 4:41 pm
If you Split Stereo Track you can edit the channels independently. Then you can use the Amplify effect (or other effects) on one channel at a time.
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 5:00 pm
thanks i used to have a p;ug-in like what i want but can't find it no idea where i got it from
Re: dual amplify
Post by steve » Wed Jul 15, 2020 5:04 pm
This forum board is for help with Nyquist. I assumed that you wanted to make a plug-in, so I posted the core code that you would need. Did I assume incorrectly?
If you just want to amplify the left / right channels independently using existing tools, then see the previous post (by DVDdoug).
If you want to make your own plug-in, you just need to add appropriate headers to the code that I posted to turn it into a plug-in.
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 5:06 pm
i do have this
Code: Select all
;nyquist plug-in
;version 1
;type process
;name "Amplify left or right channel..."
;action "Amplifying one channel..."
;info "Amplify left or right channel by David R. Sky"
;control channel "Channel" int "0=left 1=right" 0 0 1
;control amp "Amplification" real "db" 0.0 -24.0 24.0
;; Amplify lef or right channel by David R. Sky, October 18, 2004
;; This plug-in was written specifically to help people who use
;; a screen reader, and people who prefer to use the keyboard
;; over a mouse.
;; Select audio in Audacity, select left or right channel and
;; amout to amplify that track (in decibels).
(if (= channel 0)
(vector
(mult (aref s 0) (db-to-linear amp))
(aref s 1))
(vector
(aref s 0)
(mult (aref s 1) (db-to-linear amp))))
Reason: fix code tags
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 5:09 pm
i tryed to add headers etc but failed like a first grader new at just need to learn much more
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 6:07 pm
this is what i tryed
Code: Select all
;nyquist plug-in
;version 4
;type process
;name "Amplify tracks..."
;action "Amplifying tracks..."
;info "Amplify by percent
;control channel "Channel" int "0=left" 0 0 0
;control channel "Channel" int "1=right" 0 0 1
(setf left-gain 0.6)   ;Amplification amount for left channel
(setf right-gain 0.6)  ;Amplification amount for right channel
(vector
it error out
Bloodrock
Re: dual amplify
Post by Bloodrock » Wed Jul 15, 2020 6:41 pm
i must be doing something when sending a reply with code thought you hit code then under it add code or what do i need to do
