Would someone be able to please advise me on the correct Nyquist code for multiplying channel A with channel B?
The intended effect is similar to analog multiplication of X and Y inputs using an IC such as an AD633. It results in changes to both amplitude and pitch.
This is different from standard modulation or mixing functions.
When I debug the code suggested above in v 2,1,2 in MX Linux I get this error message. Clicking “Preview” does nothing as well. Track i is 10s brown noise. Track 2 is 10Hz. Please advise solution.
error: bad argument type - #<Sound: #57a85710>
Function: #<Subr-AREF: #575cf018>
Arguments:
#<Sound: #57a85710>
0
1> error: bad argument type - #<Sound: #57a85710>
Function: #<Subr-AREF: #57d88de8>
Arguments:
#<Sound: #57a85710>
0
1>
Thank you. It is working now. For users of older versions, the “make stereo track” command is located not in the top menu, but within the box to the left of each track. Click on downward pointing arrow.
