To set the operating system, click on the “User Control Panel” link near the top left corner of the forum page.
Then select the “Profile” tab.
Then select your operating system from the multi-choice near the bottom of that section.
Well, I found “User Control Panel” under the user name, now.
But there is no such multi-choice in the “Profile” tab. I’ve tried with both Firefox and Safari. What’s wrong here?
Apparently, the forum software has been updated again, so now in August 2020 the profile option to change the operating system no longer exists (or at least I can’t find it following the Username → Profile menu).
Is there some other way to accomplish this? Thanks.
Thanks, Walter, but although “Profile” is present, the OS setting definitely does not exist there under Windows 10 using Firefox or Waterfox. I’ll try other browsers and report back…
I have the same issue as the person above - can’t change the os I use in my profile - I put the wrong one by mistake when I registered for the forum.
I tried changing it on Firefox via Mac OS and Safari via Mac IOS, but don’t see any options to change it.
my OS should read Linux/Debian
Thank you.
