Switch to MyBB
Suggestions and Questions About the Forum Web Site.
ImagePost here only if the Forum isn't working as you would like or expect.
If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
xaoseric
Switch to MyBB
Post by xaoseric » Thu Jul 24, 2014 12:32 pm
Ok, so audacity has been using phpbb for a while, however, phpbb has had the same theme for a while and there it is not really mobile friendly as I keep having to login on my iPad. So, I suggest switching to MyBB. With mybb, it is more updated, and it works better on mobile devices. I think it would be good for some change in Audacity, and MyBB is more modern as well in terms of features.
Re: Switch to MyBB
Post by steve » Thu Jul 24, 2014 1:46 pm
Switching to MyBB has been considered before, but there were problems migrating the database.
I see that the MyBB Merge System has recently been updated, so this may be worth reconsidering.
