Move message to correct thread
Suggestions and Questions About the Forum Web Site.
ImagePost here only if the Forum isn't working as you would like or expect.
If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
stepheng
Post by stepheng » Tue Jan 14, 2014 11:00 pm
<<stepheng wrote:
My post of Jan 13, 2014 5:44 pm got placed after Gale's Jan 13, 2014 5:04 pm
instead where it belongs after Gale's Jan 13, 2:26 pm.>>
<I assume your post was moderated as you had not made many posts yet. This would mean it would not appear immediately.
Please post in viewforum.php?f=32 if you think there is some issue.
Thanks,
Gale>
Why not just move the message from one thread to the other?
That way kingstonp would know mp3 import works and what I did to make it happen.
-Steve #2
Contact:
Re: Move message to correct thread
Post by Gale Andrews » Tue Jan 14, 2014 11:37 pm
Thanks for contributing to the topic but I don't understand the relevance of your contribution to kingstonp at the point you submitted it.
If you read the topic (between the lines) you'll see that on Mon Jan 13, 2014 at 11:58 am kingstonp had already been able to configure LAME so they could export. Their issue was then that they wanted to put a dot in the filename (which most of the rest of the topic is about) and that they wanted to overwrite the file. Your post does not address those issues.
