Choosing Audacity Software version
Suggestions and Questions About the Forum Web Site.
ImagePost here only if the Forum isn't working as you would like or expect.
If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
Permanent link to this post Posted by hoodoo » Mon Jul 19, 2010 3:23 pm
I want to record my own, voice and guitar, and sometimes additional tracks. It would be all my own stuff. No importing sounds or music from anyone or anywhere else.
I read that 1.2.6 is stable. I want stable. I want simple. I want as few problems as possible.
I read that 1.3.12 is not stable (yet) and is under development by hosts and users. The word "beta" is part of the description - no idea what that signifies. I read that 1.3.12 is suitable for a Windows 7 O/S, which I have, and that it is basically recommended that only 1.3.12 be downloaded for a Windows 7 O/S. I also read and infer that part of the reason for this is to involve 1.3.12 users in perfecting the version. So what's paramount - the need for help in finding and working out glitches, or the precise and exclusive suitability of 1.3.12 for Windows 7?
I'm all for helping, but I'm not adept, conversant, or fluent in anything about software. Which should I choose? Is there even a choice, i.e. does 1.2.6 not work with Windows 7 at all?
After I've figured out which to download, how do I do that. All the pages that say "download" seem to only take me somewhere else where there's more explanatory text rather than the actual download.
Thanks,
Hoodoo
hoodoo
Re: Choosing Audacity Software version
Permanent link to this post Posted by whomper » Mon Jul 19, 2010 4:05 pm
what are you recording with ? win linux mac other
laptop or real pc
internal or external interface ?
hey
its free
download and see if its good enough for your requirements
as a user and not a honcho here i think the word stable and beta have slightly different meanings than the rest of the world
stable seems to be a version that they are not working with anymore
beta means the current flavor with probably some big enhancements that dont fit with the previous stable version
this is an ongoing effort
so it is always beta so to speak
if they ever get this one "perfected" then it will be stable
while they try to add some big new features to the next beta
whomper
Probationer
Permanent link to this post Posted by hoodoo » Mon Jul 19, 2010 4:18 pm
I'm recording with the following:
microphone for single track guitar or guitar and voice recordings, or same mike for doing multiple tracks with voice and various instruments.
The mike is plugged into an MAudio MobilePre interface device (external).
That device goes into the computer:
Dell Studio XPS 9000 - a more than adequately "strong" desktop model
O/S is Windows 7, (i.e microsoft)
Does the above affect any answers?
Thanks.
Still wondering what link/locale starts the actual DOWNLOAD as opposed to pressing "download" in several locations and then just being switched from explanatory text to text to more text.
hoodoo
Permanent link to this post Posted by whomper » Mon Jul 19, 2010 4:27 pm
if you have an external interface with latest drivers you should be okay
but internal soundcards on win7 especially laptops can be a big problem
which is not to say you wont still need to find and set some win7 options. the desktop should be good. my dell desktop had a faulty internal sound card so i need to use an external interface.
dont know about downloads
i get the latest version on a cd from a magazine like max pc or similar
whomper
Probationer
Permanent link to this post Posted by steve » Mon Jul 19, 2010 5:19 pm
hoodoo wrote:I want stable. I want simple. I want as few problems as possible.
Audacity 1.3.12
hoodoo wrote:I read that 1.2.6 is stable.
In my opinion that should be written in the past tense. "Audacity 1.2.6 was the stable version".
Hardware and operating systems have moved on, leaving the 1.2.x branch as a "legacy" product.
hoodoo wrote:I read that 1.3.12 is not stable (yet)
It is the most stable version for the majority of users. I've been using it as my production version since before it was officially released.
It is not yet perfect, so the recommendation is to follow "good practice" and make backups as you go along, but it is sufficiently stable that many commercial companies would remove the "beta" label without a second thought.
hoodoo wrote:and is under development
Yes, some features are under development, for example there are a couple of developers looking at improving effectiveness of the Noise Removal effect. There are other new features in the pipeline, but they do not get into the beta release until they are known to be substantially stable. The really "experimental" stuff stays in the Experimental branch and is only available for users that either build Audacity from the source code, or choose to test out the alpha versions.
The 1.3.12 version has been out for a good while now with few problems, so the developers do not seem to be in a hurry to bring out a new beta version. As stability is your major concern, I'd recommend using Audacity 1.3.12 and not upgrading to 1.3.13 until it has been out for a while (unless of course you run into any bugs in 1.3.12 which are fixed in the next release).
hoodoo wrote:Which should I choose?
1.3.12
hoodoo wrote:does 1.2.6 not work with Windows 7 at all?
I don't think it works very well - we've seen quite a few people on the forum try to use it and then have problems - upgrading to 1.3.12 invariably solves their problems.
hoodoo wrote:Still wondering what link/locale starts the actual DOWNLOAD
Go to this page: http://audacityteam.org/download/
Where it says "best version for Windows 7" - that links to a page that you should read.
Where it says "Windows 1.3.12" - that link takes you to this page:
http://audacityteam.org/download/beta_windows
On that page, look for the words:
"Recommended Download
* Windows 2000/XP/Vista: Audacity 1.3.12 installer (.exe file, 11.3 MB) - The latest version of the free Audacity "
That is the actual download link.
Return to Maintaining / Improving this Forum
Who is online
Users browsing this forum: No registered users and 2 guests
