The links in "Find quick answers in our Tips, Tutorials and Documentation!" are no longer pointing to the correct web pages.
And the Logo image on the forum header is missing.
Forum Links need updating
Post here only if the Forum isn't working as you would like or expect.
If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
Post here only if the Forum isn't working as you would like or expect.If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
- Quality Assurance
Re: Forum Links need updating
The Documentation link is completely correct. Given we have redirects in place from http://audacityteam.org/wiki/ to http://wiki.audacityteam.org/ for obvious reasons, I've never bothered to update those. Easy enough to do so for the Forum, so I've done that now. Are you saying the redirect was failing again? It was doing so intermittently yesterday.stevethefiddle wrote:The links in "Find quick answers in our Tips, Tutorials and Documentation!" are no longer pointing to the correct web pages.
stevethefiddle wrote:And the Logo image on the forum header is missing.
I had noticed
I'm not sure what the problem was. The file on the server was still there and overall_header.html had not been changed. The link went to:
http://audacityteam.org/forum/styles/pr ... _forum.png
which fails, yet if you go to:
the redirect to:
http://forum.audacityteam.org/
works. Anyway the link is now to:
http://forum.audacityteam.org/styles/pr ... _forum.png
which should work as there is no redirect. We can't simply use the LOGO syntax to use the installed logo because that doesn't allow (as far as I know) the use of a tooltip or target=blank.
