Any chance we can lose the "Save" function on the forum
Suggestions and Questions About the Forum Web Site.
ImagePost here only if the Forum isn't working as you would like or expect.
If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
waxcylinder
Post by waxcylinder » Fri Aug 17, 2007 6:57 pm
When replying to posts it is far too easy to hit the "Save" button by mistake - and like another poster I responded to recently, I've never figured How to retrieve the draft - so end up having to retype the reply.
Personally I think the "Save" function is a waste of space and would galdly see it removed.
alatham
Contact:
Re: Any chance we can lose the "Save" function on the forum
Post by alatham » Fri Aug 17, 2007 6:58 pm
agreed.
Contact:
Post by Gale Andrews » Fri Sep 28, 2007 7:11 am
waxcylinder wrote:When replying to posts it is far too easy to hit the "Save" button by mistake - and like another poster I responded to recently, I've never figured How to retrieve the draft - so end up having to retype the reply.
Go to your user Control Panel top left of any Forum page, there is a tab "Manage Drafts" on the left then there are links "Load Draft" or "View/Edit" in the message itself. You can then edit and submit the post from there.
I told Buanzo the first time I saw Save/Preview/Submit that people would be clicking Save in error. He said he thought this was in the software shell itself so may be hard to change. I'll give him a nag to look into it if he has time. I think we should be able to save drafts but the "Save" button should be called "Save Draft" and "Submit" should be "Post" or "Submit Post".
buanzo
Post by buanzo » Sat Sep 29, 2007 3:36 pm
galeandrews wrote:I told Buanzo the first time I saw Save/Preview/Submit that people would be clicking Save in error. He said he thought this was in the software shell itself so may be hard to change. I'll give him a nag to look into it if he has time. I think we should be able to save drafts but the "Save" button should be called "Save Draft" and "Submit" should be "Post" or "Submit Post".
Sorry, but your wrong. What I said, and I'll keep on repeating it, and I expect someone to LISTEN this time around, is that the forum software is BETA, and that no template or new features will be modified/added until phpBB releases the final stable version.
It's definitely NOT COMPLICATED to remove a simple button from a simple template file. But as that, and many other, areas are changing in the phpBB code, then I strongly suggest not to mess around with it.
And the choice of using thephpBB beta was discussed between Dominic and I when he hired me to do the Sys Admin job at the Audacity Project.
jotti
Post by jotti » Tue Oct 09, 2007 7:17 pm
I would agree to the suggestion. But if the button has to stay there, maybe the text could be changed to "Evil Save".
