How do I make a smiley? Or more to the point, include one that I make?
I know how to make favicons (badly). Is there a smiley formula?
New Smiley
Post here only if the Forum isn't working as you would like or expect.
If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
Post here only if the Forum isn't working as you would like or expect.If you require help using Audacity, or think you have found a "bug", please post on the forum board relevant to your operating system.
Re: New Smiley
These Smiles are installed as part of the forum software:
Each of them has an associated code so that when the forum software sees the code in a message, it replaces the text code with a graphic.
These are the codes that are in use.
Only the forum administrator has access to changing these Smilies.
If however you have an image (example - smilie.gif) that you wish to insert into a message, you can put that image onto your web space (or anywhere on the internet) and display it using the "Img" tag (See the
Code: Select all
:D :) ;) :( :o :shock: :? 8-) :lol: :x :P :oops: :cry: :evil: :twisted: :roll: :!: :?: :idea: :arrow: :| :mrgreen: :geek: :ugeek: If however you have an image (example - smilie.gif) that you wish to insert into a message, you can put that image onto your web space (or anywhere on the internet) and display it using the "Img" tag (See the
Re: New Smiley
Yes. The moving ones are animated GIFs, right?
Re: New Smiley
Yes, and unlike the one I posted, they should have a transparent background.kozikowski wrote:Yes. The moving ones are animated GIFs, right?
