I have a piano-and-voice recording. At one point, the singer holds a note with heavy vibrato for about 6 seconds. For the first half second or so, she is underpitch. Is there a way to raise that section without:
(1) creating clicks or other obvious editing sounds?
(2) affecting the tone of the piano in that section?
Pitch changing for only 1 instrument
Re: Pitch changing for only 1 instrument
Only if the piano and the vocal are recorded on different tracks, otherwise no.skinnyboy wrote:Is there a way to raise that section without:
Yes.
Changing the pitch isn't the job. Pitch Change is careful work with the appropriate tools. Separating the voice from the piano is the impossible part.
Also see: "Can I take the piano part out of the orchestra and use it in my Video?"
No.
No.
