Hi,
I'd like to know if it is possible to do with Audacity the following thing :
-I feed Audacity with a sound file in mono, a range (for example : from 22,534 s to 54,478s) and a specific frequency
-In return I get a curve showing the level of this frequency as un function of the time (from 22,534 s to 54,478s).
Thank you.
Analysing a frequency
Re: Analysing a frequency
I'm not sure that I understand precisely what you are trying to do, but Audacity's "Spectrogram" track view displays frequency against time: http://manual.audacityteam.org/man/spec ... _view.html
Thanks.
