Importing x264_divX_mp4
nicoliani
Post by nicoliani » Fri May 01, 2009 8:30 pm
I'm trying to import a movie clip, which I need the sound for. Although I get an error message.
In Preferences I do as told, downloading the FFmpeg library, but nothing happens. I have K-lite codec pack, so maybe I already have the required avformat-52.dll, but where do I locate it?
nicoliani
Re: Importing x264_divX_mp4
Post by nicoliani » Sun May 03, 2009 11:57 am
Bump.
Post by kozikowski » Mon May 04, 2009 5:36 am
<<<Bump.>>>
If the question had time to ripple around the earth once, then we have no idea.
waxcylinder
Post by waxcylinder » Mon May 04, 2009 11:55 am
You could try converting the sound clip to a format that Audacity can work with - I would suggest WAV. A converter that gets mentioned a lot is Super (which come from eRightSoft IIRC)
nicoliani
Post by nicoliani » Wed May 06, 2009 6:39 pm
Danke, but "free" Sony Acid handles it just great.
