Hello,
Is it possible to play a wav file of a chord and get a print out of the double stave notation for the chord?
Cheers,
Geoff
chord notation?
Re: chord notation?
No. That's sounds like something you would need a MIDI controller or sequencer to do. The problem is in recognizing which key you pressed...
http://www.kozco.com/tech/audacity/piano_G1.jpg
That's an analysis of either a chord on an organ or one single note on a concert grand piano. There's no way to tell other than take my word that it's the piano because I played the note.
MIDI, on the other hand, isn't music. It deals strictly with passing instructions and music data back and forth and it's a snap for a controller to build sheet music from the physical keys you pressed.
If there are no physical keys, if you're trying to do this with with downloaded music, then no.
Re: chord notation?
Thanks for your reply Koz.
Cheers
Geoff
Cheers
Geoff
