How to swap *only selected* audio parts between two channels
george-fx
Post by george-fx » Mon Dec 19, 2016 11:57 pm
Hi all, is there an easy and quick solution in Audacity to this:
I often make a spoken word stereo recording, which consist of synced input from two mono microphones, each recording a different person (such as speaker-translator, or an interview between two people, etc.) located at places near each other.
In this setup, both microphones record the voice of person in front of them, but also voice of the other person, talking in front of the other microphone - with lower volume and quality of the sound. So, at any given time, one of the channels contains the best quality recording, while in the same time the other channel contains the lower quality record of the same.
However, each person needs to have his own mic, mic sharing is not possible. It is also not practically possible to switch the mics on/off during the recording.
These recordings can last more than 2 hours, and those two people are constantly alternating - first person says one sentence, the other one translates it, etc., making numerous swaps during the recording.
The result I'm looking for is a mono output, where at any given time, only the microphone of speaking person is heard, and where the original flow of time is perfectly preserved (mics are only alternating, but every moment of audio is captured, with one mic or another).
When I just simply mix the original stereo track to mono, it gives some usable result, but the lower quality input, "overheard" by the other mic, distorts the resulting recording at any given time. I would like to be able to tell Audacity manually, at what point which mic should be muted and which mic should be aloud.
To get better result, I wondered if I could manually select several parts of stereo track (sentences), then swap left and right channels only for those selected sentences - as a result, there would be one channel containing only high quality sentences, and the second channel would contain only the low quality version of the same sound. Then, delete the low quality channel, and save the high quality one as mono.
Or, if I could add some marks into the recording, which would dynamically mute or unmute channels as needed, at exactly the same time.
Is there a chance that this could be done somehow in Audacity, perhaps by using some plugin, etc.? Many thanks for any suggestions.
Re: How to swap *only selected* audio parts between two chan
Post by kozikowski » Tue Dec 20, 2016 2:17 am
Can we assume the "bad" sound is always lower volume than the prime voice? You may be a candidate for Noise Gate.
http://wiki.audacityteam.org/wiki/Nyqui ... Noise_Gate
Split the stereo show to two mono tracks with the drop-down on the left. Select one of the two tracks and apply Noise Gate. You might be able to hit a setting where all the bad audio drops to silence. Repeat with the other track. This isn't going to work if the performers like to be expressive or weave around a lot. But it's worth a shot.
There is also Auto Duck. You apply that to a voice track and a music track and it's supposed to automatically reduce the volume of the music during voice. I have to look that one up.
koz
Post by kozikowski » Tue Dec 20, 2016 2:21 am
Auto Duck is a part of the Effect set in Audacity 2.1.2. Split into two monos. Use it twice. Once right-side up to suppress track 1 and again upside-down to suppress track 2.
Post by kozikowski » Tue Dec 20, 2016 3:25 am
Post by steve » Tue Dec 20, 2016 3:30 pm
george-fx wrote:as a result, there would be one channel containing only high quality sentences, and the second channel would contain only the low quality version of the same sound. Then, delete the low quality channel, and save the high quality one as mono.
An alternative approach would be to "mute" (silence) the "bad" parts, then mix to mono.
Here's two little snippets of code that can be used in the Nyquist Prompt effect:
Code: Select all
;version 4
;type process
;; This will silence the left channel
(vector
  (s-rest 1)
  (aref *track* 1))
Code: Select all
;version 4
;type process
;; This will silence the right channel
(vector
  (aref *track* 0)
  (s-rest 1))
If you would prefer to use a plug-in, then you can do the same (or swap the channels as you originally intended) using the Channel Mixer plug-in: http://wiki.audacityteam.org/wiki/Nyqui ... nnel_Mixer
See here for download/installation instructions: http://wiki.audacityteam.org/wiki/Downl ... s#download
Post by kozikowski » Tue Dec 20, 2016 5:10 pm
Given the job is a ping-pong interview, is repeatedly invoking nyquist easier than split-playing the presentation and control-L silencing the parts you don't want?
Post by steve » Tue Dec 20, 2016 5:31 pm
kozikowski wrote:Given the job is a ping-pong interview, is repeatedly invoking nyquist easier than split-playing the presentation and control-L silencing the parts you don't want?
Ctrl+R to repeat the last effect.
Not much difference really, except that you don't need to split the track.
george-fx
Post by george-fx » Tue Dec 20, 2016 7:40 pm
Many thanks guys, I'll try your suggestions within a few days and let you know how it went.
I'm actually a total beginner and have no "pro" level of knowledge in anything related to sound engineering, so it might take me some time.
Regarding the question:
kozikowski wrote:Can we assume the "bad" sound is always lower volume than the prime voice?
I'm not really sure, but most probably not. It sounds as if the sound volume was subjectively lower, but it really might be a different quality mostly, caused by the "proximity effect" of a particular mic. When I look at the soundwave visualization in Audacity, the difference does not seem to be that much, as the second mic with a lower quality distorted signal probably also picks up many other sounds, such as some reflections from room walls and other noise. Due to the recording quality requirements, I use phantom-powered condenser mics, so their pick-up capabilities are generally pretty good. Also, sometimes the setup is one-to-many, where one supercardioid mic records a main speaker person, while other cardioid mic records a group of people (a discussion). In that case, even at the time when the main speaker is the only one talking, the sound from the secondary (group) cardioid mic might be stronger than the one from the speaker, but I would still want the (possibly lower volume) output from the main supercardioid speaker mic, as the quality is much better and due to its pick-up pattern it does not include significant noise and wall reflections ("the sound of the room").
kozikowski wrote:There is also Auto Duck. ...
This looks very interesting. I'm thinking that I could even create a special, separate control channel for use with the AutoDuck feature only (to be deleted later), by copying one of the original channels and then manually emphasizing some parts of it by making them very loud and others make totally silent. This way I could possibly improve my control over the AutoDuck behavior, as to when exactly it gets activated.
And as an additional plus, the AutoDuck might provide nicely another thing, which I also thought about: making a "micro cross-fade" (e.g. within half a sec or so) between the two channels, so that alternating changes of microphones does not feel too abrupt when listening.
I'm just wondering, if there will be a way how to create only one "special control channel" (with loud sound and total silence) and use it for AutoDucking both channels (one after another, and with opposite effect), or if I will have to create two special control channels, for each original channel separately. But thinking about that, perhaps I could use the first AutoDucked channel as a control channel for the second channel AutoDuck. :)
Anyways, thanks a lot again, and I'll try and see.
Post by kozikowski » Tue Dec 20, 2016 7:55 pm
Any other ideas how to automate it, split or not?
@george-fx
Which microphones are you using? There are ways to avoid interference and noise in an interview. In your case, the "wrong person" is considered noise to the other.
That interview spacing is not an accident and they're both wearing lavaliers.
Post by kozikowski » Tue Dec 20, 2016 8:19 pm
Dueling posts.
So you're trying to record a conference. There is only one good way to shoot that given you don't have supervisory control of the performance ... or a crew. Give up trying to capture theatrically perfect and use an actual conferencing system with Auto Duck, Noise Reduction and Echo Cancellation built in. There's just nothing like a recording system that "knows" what a voice is.
It may seem like a good idea to go down a performance correcting it word by word or phrase by phrase, but if this goes beyond an interesting hobby, that will get old in a hurry.
Press Stop at the end of the performance, cut off the messy ends, adjust volume a little and post the finished show.
Drive to the next performance.
There was a recent posting from someone who was correcting his audiobook ..... word ... by ... word. That may take longer than the person who wrote the book. Not likely to last past one reading and not viable if you're too close to retirement.
