absolute time of recording
Re: absolute time of recording
Post by kozikowski » Fri Nov 25, 2016 5:39 pm
Window on the bottom? Point to a place on an hour recording. How hard is it to figure that time?
So export the work, read the time and figure the differential offset.
I think Casio made my time calculator. I remember having to save up for it. It's really cool. It will calculate directly in television drop-frame time code for those countries so afflicted.
You can't figure time on a regular calculator.
Maybe there's an App....
Post by kozikowski » Fri Nov 25, 2016 5:41 pm
Wasn't there a thing about not being able to get seconds or fractional seconds from Windows? It's the reason you can't reconstruct your show from the _DATA folder.
Post by steve » Fri Nov 25, 2016 6:25 pm
kozikowski wrote:Window on the bottom? Point to a place on an hour recording.
If you mean while it is recording, just look at the "Length".
kozikowski wrote:Wasn't there a thing about not being able to get seconds or fractional seconds from Windows?
When writing to disk, the precision (granularity) of the time stamp depends on the file system.
NTFS (Windows) has a maximum (at best) resolution/ranularity of 100 ns.
FAT had a granularity of 2 seconds
For ext4 (Linux) it's 1 ns
The new timestamp feature in Audacity 2.1.3 gives: hh-mm-ss
Date is as: yyyy-mm-dd
Date and time as: yyyy-mm-dd_hh-mm-ss
Axel_
Operating System: Windows 7
Post by Axel_ » Fri Nov 25, 2016 8:21 pm
steve wrote: ... automatically add the date and time to the name of newly recorded tracks. (The "start time" of the recording). .
So you still have to add manually the cursor position(s relative time) to the start time extracted from the name ?
No way to see the absolute time of the cursor as you scan through the recording ?
Reason: fixed quote tag
Post by steve » Fri Nov 25, 2016 9:03 pm
Axel_ wrote:No way to see the absolute time of the cursor as you scan through the recording ?
No.
Post by kozikowski » Sat Nov 26, 2016 2:59 am
Attached a valuable tool in this quest.
Apparently, there was a FrameMaster II.
http://mathcs.albion.edu/~mbollman/CI/FrameMaster2.htm
The Producer was scribbling notes from the clock on her phone during the shoot. Here's a list of the cuts she thinks might work.
Once you pass basic recording your guitar, bookkeeping is a really big deal.
Post by kozikowski » Sat Nov 26, 2016 3:24 am
I haven't done this in a long time, but you can "record" a standard offset and then keep recalling it to rapidly convert back and forth.
Are you sure there isn't an APP for that?
Post by kozikowski » Sat Nov 26, 2016 5:33 am
Even if Audacity doesn't obsessively track every nsec, it would be insanely handy to be able to set one of those timers on the bottom.
"See that cursor? That cursor is sitting at 16:30:00 GMT. Work from that."
Post by steve » Sat Nov 26, 2016 1:04 pm
1) Press "Record" - The timeline / Selection toolbar shows 26th Nov 13:02.050 (or something like)
2) Press "Pause" - Now the time shows as 13:12.123
3) Unpause - what time is it now?
Post by Gale Andrews » Sat Nov 26, 2016 4:32 pm
I moved this to "Adding Features".
