Isolating Instruments
Hoho5000
Post by Hoho5000 » Wed Nov 02, 2016 10:53 pm
I know this has been asked a million times, but I promise, this is different. :D
I have several recordings of songs that have five parts (guitar 1, guitar 2, bass, keys, drums). All the files are in stereo flac format. I have "practice" tracks for each one of the parts where that specific instrument is omitted from the recording. There are also instrumental, and instrumental + vocals tracks. I've been able to get very clean isolated channels by aligning and subtracting each part that is missing an instrument from the main instrumental track. However, there is unfortunately one song that gives a lot of bleed through of each part when trying to do this. I guess the instrumental doesn't match up as well waveform-wise with the practice recordings.
By picking two practice tracks at a time and subtracting one from the other, I can get clean separation with pairs of instruments, but is there any way to narrow it down to a single instrument from this method? It's not the worst thing in the world if this is as far as I can get with what I have, but it would be preferred to isolate each instrument. Thanks!
Re: Isolating Instruments
Post by kozikowski » Thu Nov 03, 2016 2:08 am
this is different.
You're right. This is different. I would not have bet you could make it this far.
I bet you're at the limits of FLAC. Even uncompressed formats have some errors. They have to bust up sound in individual chunks (sampling rate) and then code each chunk (bit depth). Audacity uses 32-bit floating for an internal bit depth for terrific accuracy during effects and filtering, but external sound files typically only use straight 16-bit. And FLAC piles its compression algorithm on top of that.
