Mixing/editing vocals?
Alex the Angel
Post by Alex the Angel » Sun Oct 23, 2016 3:31 pm
So, I'm an aspiring Metal artist, and have only just recently started putting vocals in my tracks. However, whenever I do so, I notice that the vocal recordings sound very out of place as if they don't belong in the mix. I'm still pretty new to audio editing, so I've had trouble understanding a lot of the tutorials I've read.
So here's what I'm using.
Audacity v2.1.0
Magix Music Maker Rock Edition 4
Blue Snowball Ice USB Microphone (Because budget.)
Any tips?
Re: Mixing/editing vocals?
Post by kozikowski » Sun Oct 23, 2016 11:50 pm
Can you post some of a mixed song? We would normally urge you to post WAV as a forum attachment, but we're not going to surgically rip apart your blue waves, so a good quality MP3 should do it. At least 128 MP3 quality.
Scroll down from a forum window > Upload attachment.
The forum will tell you if the posting is too large. In perfect quality WAV, the show size tops out at 20 seconds. MP3 will do better but you're not going to get a 3 minute song on here.
This is where we find out you have a voice that frightens pets and small children.
Alex the Angel
Post by Alex the Angel » Fri Oct 28, 2016 9:48 pm
Not a problem! I have a short sample recorded here. The only thing I did with the vocals was added noise reduction and lowered the volume a bit.
Sample 1.MP3
I strongly advise covering the ears of any puppies or small children within the vicinity~.
(234.29 KiB) Downloaded 111 times
Post by kozikowski » Fri Oct 28, 2016 11:40 pm
This is the clip somebody posts with the complaint that there's distortion in the instrumental part.
Alex the Angel
Post by Alex the Angel » Sat Oct 29, 2016 3:22 am
kozikowski wrote:This is the clip somebody posts with the complaint that there's distortion in the instrumental part.
Wait, distortion in the instrumental part? I was asking about editing the vocals because they sound out of place. :lol:
Post by kozikowski » Sat Oct 29, 2016 3:45 am
That's a joke. Somebody posts heavy metal with its 99% distortion guitars and complains in the post of excessive distortion.
How would you know?
I only heard the voice at the beginning and then it faded out. Was it supposed to be there for the whole clip?
Do you have the voice on is own track with no music? You need that to add effects, tools and filters without screwing up the guitar track.
In case I missed the boat here, you might try Effect > Echo on your voice only to give it a little concert hall effect. That might help it melt into the guitar.
OK, here's one. Point to someone you're trying to sound like.
Alex the Angel
Post by Alex the Angel » Sat Oct 29, 2016 4:01 am
Ah, I see. XD
Anyway, to answer your questions...
1. No, the vocals weren't supposed to be for the entire clip. There's basically the first phrase ("We will succeed", if you didn't understand it.), and then a little "RAH!" Near the end.
2. Yes, the vocals are on their own track. I usually like to edit things separately before I put them all together.
3. I have tried using Echo before. It helps a bit, but it's still not quite there. I hear that using a compressing it a lot kinda helps, I've also read that usually vocals sometimes have a bit of a problem with the "wall of guitars" thing.
As for who I'm trying to sound like... that's a bit difficult, as I've been trying to be more original. However, I will say maybe Randy Blythe from Lamb of God may be the closest resemblance.
Post by kozikowski » Sat Oct 29, 2016 5:20 am
The compressors and limiters go through a lot of work to make sure they don't add any more distortion than needed. Leveler, however, doesn't care. Try adding Leveler multiple passes at maximum setting.
Alex the Angel
Post by Alex the Angel » Sat Oct 29, 2016 5:35 am
Hm... can't say I've ever used the Leveler before. Also, multiple passes? Sorry... Like I said, I'm extremely new to audio editing. XD
