Strange Trumpet Sounds in Audacity.exe (2.1.2)
Peekofwar
Post by Peekofwar » Thu Oct 06, 2016 4:00 am
I saw someone do this with 'undertale.exe', so I did this with a few exe files myself. One of those was 'audacity.exe' I found something that sounds similar to the music associated with the moon landing (especially if you slow it down more). Take a listen!
audacity.exe trumpet sound.ogg
(370.8 KiB) Downloaded 62 times
Trebor
Re: Strange Trumpet Sounds in Audacity.exe (2.1.2)
Post by Trebor » Thu Oct 06, 2016 6:25 pm
Peekofwar wrote:... the music associated with the moon landing ...
https://wikipedia.org/wiki/Fanfare_for_the_Common_Man
weldo5
Post by weldo5 » Thu Oct 06, 2016 7:17 pm
It's the program's raw bits as if it were imported as RAW. Youll hear all sorts of weird sounds like that when rawing exe files.
Peekofwar
Post by Peekofwar » Thu Oct 06, 2016 8:22 pm
weldo5 wrote:It's the program's raw bits as if it were imported as RAW. Youll hear all sorts of weird sounds like that when rawing exe files.
Then why did it happen multiple times in the same sequence? This could be a binary file (or something similar).
weldo5
Post by weldo5 » Sat Dec 10, 2016 1:59 am
The reason for repeats in sequence, is the binary loops that were contained. Either its the source code that was translated to binary before saving it as the exe, mustve been repeated. Or something else I can't remember.
