Tone Generator Inaccuracies?
sonusmagus
Post by sonusmagus » Thu Jun 16, 2016 9:06 pm
I need to create very accurate tones @ 96K
I tried to create a 830.61Hz sine wave @ 96K
To get a perfect loop I should be able to multiply 830.61 X 9600 = 7973856 (or 83.061 seconds)
Then simply set start of loop at zero and end of loop at 7973856 and it SHOULD be 100% accurate
When I generate the tone and look at what has been calculated, something is wrong
This has always worked for me with Sound Forge
Any ideas on this?
Thanks
TINLEY
Re: Tone Generator Inaccuracies?
Post by steve » Thu Jun 16, 2016 11:19 pm
A frequency of 830.61 Hz has a period of 1/830.61 seconds.
At 96000 Hz sample rate, to convert seconds to samples, multiply seconds by 96000.
So a single cycle at 830.61 Hz would be 96000/830.61 = 115.57770795 sample periods.
68991 cycles of 830.61 Hz at 96000 Hz sample rate would be:
1 cycle period = 96000/830.61 samples
68991 cycles = (68991 * 96000)/ 830.61 = 7973821.64914942
So 7973822 samples will be very nearly perfect.
sonusmagus
Post by sonusmagus » Thu Jun 16, 2016 11:31 pm
I had the first calculation, thanks
But where does 68991 come from?
What would make it perfect?
Can I do this:
83061 cycles of 830.61 Hz at 96000 Hz sample rate would be:
83061 cycles = (83061 * 96000)/ 830.61 = 9600000
So 96000.00 samples will be perfect
I was trying to account for the two decimal places and over complicating it
Now makes perfect sense to me
Thanks
TINLEY
Post by steve » Fri Jun 17, 2016 12:50 am
sonusmagus wrote:But where does 68991 come from?
I looked for the closest number of complete cycles to your figure of 7973856 samples.
To do that:
We know that 1 cycle is: "(sample rate)/frequency" samples.
How many cycles in 7973856 samples = (number of samples)/(samples per cycle)
Which gives us:
7973856/(96000/830.61)
= 68991.29721 cycles
Rounding to the closest number of cycles = 68991 cycles.
sonusmagus wrote:What would make it perfect?
Any whole number of samples that is an exact multiple of 96000/830.61
Try 100 seconds
Post by steve » Fri Jun 17, 2016 1:27 am
steve wrote:Any whole number of samples that is an exact multiple of 96000/830.61
Try 100 seconds
or 3,200,000 samples (33.333 seconds)
Robert J. H.
Post by Robert J. H. » Fri Jun 17, 2016 10:03 am
Try 100 seconds
that's a pretty nasty frequency, isn't it?
The exact value (to 50 places) would be:
830.60939515989027704488357786743025088666010693809 Hz
The question is now how much accuracy one wants.
Steve's 33.3... seconds are perfect for 830.61 Hz
For 830.609 Hz it would be:
1,000 s / GCD(96,000,000 , 830,609) = 1,000 / 1 = 1,000 seconds
and for 830.6094 Hz:
10,000 s / GCD(960,000,000 , 8,306,094) = 10,000 / 6 = 1,666.667 seconds
That's the problem with such irrational, transcendental numbers... ;)
Robert
Post by steve » Fri Jun 17, 2016 10:41 am
Robert J. H. wrote:The exact value (to 50 places) would be:
Is that for G#5/Ab5 at A440?
Robert J. H.
Post by Robert J. H. » Fri Jun 17, 2016 11:02 am
Exactly, for equal temperament to be precise.
Robert J. H.
Post by Robert J. H. » Fri Jun 17, 2016 11:20 am
Here's the Octave formula for the frequency value:
>> vpa(sym(440)*2**(11/sym(12)))
It works only with the Symbolic package installed.
Post by Gale Andrews » Fri Jun 17, 2016 2:47 pm
I guess this is of most interest in the "Audio Processing" board so I moved it there.
