Recording sustained tones
doubtless
Post by doubtless » Thu Mar 19, 2009 9:14 pm
I just downloaded Audacity 1.3.7 (Unicode). It records short tones fine, but any sustained tone (or tones) over a couple of seconds drops off into a wispy whiney tunnely sound at low volume. If I stop the tone, and keep on recording, the next occurrence of the tone seems to pick up at normal volume, but the same thing happens again after a few seconds.
Thanks,
doubtless
Re: Recording sustained tones
Post by steve » Thu Mar 19, 2009 11:22 pm
You are probably using a fairly modern computer with on-board sound card, possibly "RealTek", and have some kind of "Automatic Gain Control" (AGC), noise suppression, or echo cancellation type effect enabled. Look in the sound-card control panel (thoroughly - these settings can be very hard to find) and switch off all effects. They may be listed in the "Microphone" section of the sound card control panel.
doubtless
Post by doubtless » Wed Mar 25, 2009 4:23 pm
Thanks,
Sorry for the long delay in responding, but I had thought that I would be notified by email when someone made a reply. I will check into the settings you mentioned. Again, thanks. Have a blessed day.
Grady
doubtless
Post by doubtless » Wed Mar 25, 2009 4:44 pm
That worked! You have my endless thanks, stevethefiddle. Again, God bless you and your continued presence here.
Grady
