filtering question / challenge (morse code )
For all you Audacity "gurus" :
I'd like to remove as much as the "mechanical /metal clacking" as possible from this video's audio track, leaving only the "morse tone", which is ~780hz
I tried messing with the "noise reduction" effect, and had some limited success, but as an Audacity newbie, I'm thinking there might be better techniques ?
MIke
https://www.youtube.com/watch?v=RYhrSEERvbI
MIke
Re: filtering question / challenge (morse code )
Could try "Ultra narrow" plugin, see ... http://forum.audacityteam.org/viewtopic ... 073#p78073mstram wrote:... I'd like to remove as much as the "mechanical /metal clacking" as possible from this video's audio track, leaving only the "morse tone"...
You understand there are two different messages going on there, right? The beeps are being received even though she's not keying them, so that's the incoming message, different from what she's doing.
I found the tone annoying. I can do much of it from just her clicks—classic Morse.
CQ CQ CQ BE....and then I lose it. She's going too fast for me, although she's using a sidewinder key and is a little easier to understand than a regular up and down key.
CQ is an all-call for any response from anyone. "Seek You."
Amaze your friends.
Amaze your friends.
The ~700 hz tone is HER sending.kozikowski wrote:You understand there are two different messages going on there, right? The beeps are being received even though she's not keying them, so that's the incoming message, different from what she's doing.
There is a faint higher frequency, sounds about ~1200 that is incoming
kozikowski wrote:Y
Actually it's CQ CQ CQ DE (DE - this is)
Then it sounds like TAPHN.
Her "stylized" sending, while admired by all the old timers, is hard for a newb like me to decipher
Thanks that works but .....Trebor wrote:Could try "Ultra narrow" plugin, see ... http://forum.audacityteam.org/viewtopic ... 073#p78073mstram wrote:... I'd like to remove as much as the "mechanical /metal clacking" as possible from this video's audio track, leaving only the "morse tone"...
Since the "clacks" were in the upper frequencies (~1000+), when the filter is applied it necessarily "muffles" the sound of the ~700hz tone ( the harmonics I guess), as well as removing the clacks.
I'm guessing the "clacks" are a fairly complex signal, and might be tough to eliminate while leaving the bright harmonics of the morse "tone" ?
Yes. That is what I was expecting, but I swear she sent a B rather than D. _... Don't send anything important through me.Actually it's CQ CQ CQ DE (DE - this is)
I believe you. I didn't get that far. Given how hard it is to strip out the clicks without destroying the quality of the tone, I would still strip out the tone instead.Then it sounds like TAPHN.
Have you tried the vinyl click and pop filters and techniques?
http://manual.audacityteam.org/man/tuto ... iques.html
If the goal is to decode the message she is sending, why not just slow the recording down a factor of two.
I tried the "click and pop", but just used the default settings, didn't do anything. Looks like a bit of a complicated plugin to use.
Well the initial goal was to get rid of the clacking as I found it very annoying.
But after playing with the filter stuff, I think I prefer the clacking + high freq clarity to the "muffled" filtered tone.
Even though I'm a novice, I don't find her speed all that fast .. as long as I'm only listening to ~5 seconds at a time ... over and over
I did slow down one section but only about 10%
The problem I find is with her "stylized" sending method, combined of course with my very limited (literally weeks) of "non-experienced" listening / morse skills.
The morse software I've been using all send "perfect" morse, which is why I find the transition to trying to listen to "swing" morse a challenge.
It turns out what I thought was "TAPH/TST" at the beginning is actually "KPH/KSES/KSM" , at least that's the answer I got on a ham forum.
(Which makes sense, given the recording is taken from this event : http://www.kparc.org/bars/nights.htm
After trying the "Pop Mute" filter on that morse I deleted the post where I suggested it :mstram wrote:I tried the "click and pop", but just used the default settings, didn't do anything. Looks like a bit of a complicated plugin to use.
that plugin can insert gaps in the morse which weren't in the original message, corrupting its meaning.
