pro audacity
jack magee
Operating System: Windows 7
pro audacity
Post by jack magee » Sat Dec 19, 2015 12:52 pm
Audacity can record streaming audio when the paid audition can not.why not make a pro paid audacity which has editing functions like audition. How does the program record stream audition can not?
Re: pro audacity
Post by Gale Andrews » Sat Dec 19, 2015 3:08 pm
jack magee wrote:Audacity can record streaming audio when the paid audition can not.why not make a pro paid audacity which has editing functions like audition.
Audacity for desktop will always be free. We would greatly appreciate a donation if you're willing.
jack magee wrote:How does the program record stream audition can not?
We can't tell you because you give no information about your system. If it's Windows Vista or later, Audacity uses the Windows WASAPI loopback method built into Windows: Loopback Recording (Windows).
jack magee
Re: pro audacity
Post by jack magee » Sat Dec 19, 2015 4:33 pm
Vista 32 bit an 7 64 bit. Audacity will record stream but audition won't but audition is a better editor.If you get donations would you add to the editing to make it a bit like audition in terms of editing?
A lot of recorder you cannot hear when you record and have to change devices to hear which means you record more than needed. Audacity will just play and record. I would pay for it before i would pay for audition
Re: pro audacity
Post by kozikowski » Sat Dec 19, 2015 6:43 pm
I think you should capture in Audacity and edit in Audition. Nowhere is it written you can't have two editors. I have two. I wouldn't run both at the same time. Audacity doesn't like that.
Re: pro audacity
Post by steve » Sun Dec 20, 2015 4:41 pm
jack magee wrote:Audacity will record stream but audition won't but audition is a better editor.
Adobe Audition has some features / abilities that Audacity does not, and there are a few things that Audition can do better than Audacity, but overall I find Audacity to be quicker, easier and more productive to work with. Given that Adobe Audition is a commercial non-free application ($239.88 per year) and is developed by a team of paid developers, whereas Audacity is free, it is not surprising that there are some benefits to Adobe Audition. Having said that, Audacity does have some features/abilities that are not available in Audition, such as (in no particular order):
For the cost of 1 years licensed use of Adobe Audition, you could buy a very nice new microphone.
cyrano
Re: pro audacity
Post by cyrano » Sun Dec 20, 2015 7:14 pm
kozikowski wrote:I think you should capture in Audacity and edit in Audition. Nowhere is it written you can't have two editors. I have two. I wouldn't run both at the same time. Audacity doesn't like that.
I always run Audacity as second fiddle, next to Reaper, Garageband and Sony Sound Forge. No problem.
So if you have a problem between Audition and Audacity, I think you should blame Audition, not Audacity.
