Artificial wow and flutter
SNC
Post by SNC » Thu Oct 29, 2015 1:59 pm
Good day
I know that there is a software that can remove wow and flutter from samples recorded from a tape or vinyl (for example Capstan). But I wonder whether there is a software that, conversely, can create artificial wow and flutter (I really need that for some sound processing). I don't think it's possible with Audacity, but probably you could give me an advise of other ways to do it.
Thanks
Re: Artificial wow and flutter
Post by steve » Thu Oct 29, 2015 2:04 pm
How about adding a Time Track, and give it a wiggly envelope? (see: http://manual.audacityteam.org/o/man/time_tracks.html)
SNC
Post by SNC » Thu Oct 29, 2015 3:16 pm
Thanks, that's a good idea. But the only thing is that if I have even a 5 minute record and the flutter should be about 20 Hz then I have to manually envelope all time track every 0,2 second which is really boring. Is there a way of using preloaded patterns for time tracks?
Post by steve » Thu Oct 29, 2015 4:45 pm
Try pasting this code into the Nyquist Prompt effect and applying it:
Code: Select all
;; speed is in rpm
(setf depth 0.004)
(setf speed 45)
(multichan-expand #'snd-tapv *track* 0 (mult depth (sum 1 (hzosc (/ speed 60.0)))) 2)
SNC
Post by SNC » Thu Oct 29, 2015 6:23 pm
It says "Nyquist returned the value: 45". Nyquist output is as follows:
Code: Select all
error: unbound variable - *
if continued: try evaluating symbol again
1>
SNC
Post by SNC » Thu Oct 29, 2015 6:28 pm
Sorry, it says "unbound variable - *TRACK*", not "*"
Post by steve » Thu Oct 29, 2015 6:45 pm
Assuming that you are using the current Audacity version 2.1.1, ensure that "Use legacy (version 3) syntax" is not selected (see http://manual.audacityteam.org/o/man/ny ... rompt.html)
(The current version of Audacity is available here: http://web.audacityteam.org/download/)
Trebor
Post by Trebor » Thu Oct 29, 2015 6:59 pm
steve wrote:Try pasting this code into the Nyquist Prompt effect and applying it:
Code: Select all
;; speed is in rpm
(setf depth 0.004)
(setf speed 45)
Your "Tremolo/Vibrato" plug-in will do that (on vibrato), but has the added advantage that users can select to have the rate gradually change over time.
Post by steve » Thu Oct 29, 2015 7:24 pm
Trebor wrote: Your "Tremolo/Vibrato" plug-in will do that (on vibrato), but has the added advantage that users can select to have the rate gradually change over time.
Unfortunately the "Tremolo/Vibrato" plug-in is not suitable for long sections of audio because cumulative rounding errors (it's only 32 bit) cause the sound quality to deteriorate when applied to selections much more than a few tens of seconds.
SNC
Post by SNC » Fri Oct 30, 2015 4:29 pm
And in the following code:
Code: Select all
;; speed is in rpm
(setf depth 0.004)
(setf speed 45)
by which parameters can I change the frequency and intensity of flutter?
