I first tried this in Audacity 1.2.6, and see that it's not supposed to work there. I've now installed Audacity 1.3.7 .Looking at this as an iteration (in this example I will use increasingly narrow notches for higher harmonics):
You want to remove 60 Hz from the sound "s"
(notch2 s 60 25)
And you want to remove 120 Hz from the sound that has had 60 Hz removed:
(notch2 (notch2 s 60 10) 120 20)
And you want to remove 180 Hz from that:
(notch2 (notch2 (notch2 s 60 10) 120 20) 180 30)
In Effect ... Nyquist Prompt ... I pasted in ...
... and by choosing the Debug button, got the following message:(notch2 (notch2 (notch2 s 60 10) 120 20) 180 30)
Since doing Notch Filter manually requires a Q between 0.01 and 5, I instead tried ...error: bad argument type - #(#<Sound: #35c23a0> #<Sound: #35c2628>)
Function: #<Subr-SND-SRATE: #2180fa8>
Arguments:
Function: #<FSubr-LET*: #2183e48>
Arguments:
((W (* 2 PI (/ HZ (SND-SRATE X)))) (CW (COS W)) (SW (SIN W)) (ALPHA (* SW (SINH (/ 0.5 Q)))) (A0 (+ 1 ALPHA)) (A1 (* -2 CW)) (A2 (- 1 ALPHA)) (B0 1) (B1 (* -2 CW)) (B2 1))
(BIQUAD-M X B0 B1 B2 A0 A1 A2)
Function: #<Closure-NOTCH2: #36c4730>
Arguments:
60
10
1> [ gc: total 18640, 3682 free; samples 1KB, 0KB free ]
... and got the following response:(notch2 (notch2 (notch2 s 60 5) 120 4) 180 3)
... which could very well be the same thing. (I haven't looked closely).error: bad argument type - #(#<Sound: #35c23a0> #<Sound: #35c2628>)
Arguments:
Arguments:
Arguments:
60
10
So ... I'm applying the Notch Filter manually.
I first tried 60 Hz with a Q of 0.01 ... which was funny, because that's enough to remove all of the audio, so there's nothing left.
As an experiment, I reloaded the MP3 file, and iterated in the following way:
60Hz Q=0.5
120Hz Q=0.75
180Hz Q=1.00
240Hz Q=1.00
300Hz Q=1.00
360Hz Q=1.00
The first iteration (at 60 Hz) removed the most amount of hum, so "distracting" became "annoying". After five more the iterations, I can still hear hum ... and I can't detect that the sound is getting any better. I'll publish the audio as it is, because I've got other tracks to do, and should move on.
It would be easier if I didn't have to do six manual passes, though ....
