Suggestions on setting up a compressor &/or brick wall for
flynwill
Operating System: Linux Debian
Re: Suggestions on setting up a compressor &/or brick wall f
Post by flynwill » Wed Mar 11, 2015 2:17 pm
JeffB wrote: Thanks. If I understand it correctly then I would plug the UCA-202 into both of the Aux send jacks if I wanted to record in stereo and would level things out from channel to channel using the red gain knobs, pushing the 'pre' button for jack #1 in each column/channel. Then if I wanted to raise or lower the input into Audacity without affecting the sound levels playing into the speakers, I would use the main gain knobs for the Aux outputs, (labeled #1 & #1 in red on the pic of the mixer).
Yes that would be the idea. I would plan to do some testing to make sure it all behaves the way you expect. Also note that if you have a performer that wants to take advantage of the effects processor in that box that will consume Aux2 bus -- and further more if you were trying to record the show you'll be missing the effects in the final product (which might be a good thing depending on what they are doing.)
JeffB wrote: Are the things I've been calling "sliders" actually called "faders"? -- the sliders that control the volume of the individual channels, such as a mic or another input, such as a CD?
That's the term Behringer uses in their manual. I think either name gets the idea across.
JeffB
Post by JeffB » Wed Mar 11, 2015 2:30 pm
kozikowski wrote:I got two things that will make a world of difference.
Set up with two people.
"OK, this is the choir mic. Can you hear it? One, two, one, two. [walking over] This is the Pastor's mic. Does it sound OK? No? I'll stay here and test with you until you find it.
Be there for the shoot.
My two sound jobs that went straight into the dirt were the two where I couldn't be there.
Words to the wise.
I hope that includes me.
I was wishing for both of those. At least I was able to be there for the first one. Another tip would probably be to allot enough time to set it all up & troubleshoot if need be before the crowd begins showing up.
JeffB
Post by JeffB » Wed Mar 11, 2015 2:38 pm
Thanks again for all of the help everybody.
Our Pastor said he may set up a discussion with the company that installed the system and include me in that discussion. Hopefully we can figure out where I could connect in & record the direct feeds from all of the microphones & instruments with one unit.
Your information and suggestions should go a long way in providing a big improvement in any recording for the next time(s).
